Oops, then too late ...
But they are available. 1.2m (48") deep workbench is available on those links above (model H-7698, 72"x48", adjustable height 28-48", and 2000 lbs capacity for $450). Nothing stops you to extend the depth to 1.5m if you put a custom board over it in the same way you have planed your bench (to still have available those semicircle cuts).
You can also check the sagulator (
https://www.woodbin.com/calcs/sagulator/ ) if you haven't done yet, to check yourself why I suggested time ago plywood instead of MDF (and you can still cover it with any material you like, plywood with laminate should be a very easy material to source.).
The 'semicircle cut' idea could have been expanded further and converted into a U-shaped working area in the following way:
Area #1 : Workstation; R+D; and Rework. Three sections into one U-shaped (working) area, plus
Area #2 : a separate (mechanically independent) calibration/long-term-testing area. (if not a separate room, or EMI closed rack ! Yes, I know you dislike racks as much as banana jacks, but they have it's reasons to exist)
Your drawing shows a depth of 1.2m + space for chair, so I suppose that you have enough space to make a U-Shape possible. Otherwise you expend your time walking along your room. A U-shape doesn't mean that all three working sections need to be joined close to each other. They need to be close, but not too close. Also I don't mean that they need to be mechanically connected in single beautiful rectangular frame (in fact, you'd better have them not connected). And that is what I wanted to point out ...
Cost/time effective or not is secondary issue. Main concern is that you don't need a single 1.2m or 1.5m deep bench. In my opinion that not only is not needed, it is not desirable.
Having a calibrator or any other big instrument on a shelve on the wall, and one or several separate workbenchs in front (with a small gap between them) could be better. This way you don't transmit any mechanical vibration to the calibrator (or any other sensitive instrument). And if front bench has wheels, you can handle better how you access that heavy stuff at the end. There are workbenches with lockable casters that can move freely when you want and stay fixed on one place wherever you need. Yes, you said those boatanchors will be there permanently, except when you need to get them back and then once every 2 years you will get annoyed by this (and I hope that to be your only issue, take care when handling heavy stuff).
Many times I found myself needing extra items or instruments around and then I add movable shelves/racks/whatever to the sides to have all items nearby at 'elbow' distance (something that somebody pointed out before). That is nontrivial If I want to be time efficient, and that is usually most of the times.
Enough said, I hope you enjoy your dreamed bench for a lot of years.
Please don't take this as a negative comment. I hope it could help you, in case you need a new bench 10 years after this one.
The pegboard panel that was suggested is a good idea too for cables and common accesories. Much more if there are 'sliding pegboards' (check that on google images, or here ->
https://www.fixturescloseup.com/2019/11/21/high-density-sliding-pegboard-display-details/ ). Rotary shelves are nice too for small items, but expensive.
Are all the aluminum rails already cut to size or will they deliver in bulk and you need to cut them?
