Author Topic: TS555 pin layout  (Read 587 times)
Offline loistvanTopic starter
TS555 pin layout
« on: September 24, 2021, 05:57:24 pm »
I'm trying to solder a TS555IDTTR timer IC into my pcb, but there is no apparent marking on the package to denote pin 1. How to resolve this ambiguity, how to determine the correct orientation of the chip? Thanks!
Offline Gyro
Re: TS555 pin layout
« Reply #1 on: September 24, 2021, 06:06:09 pm »
Welcome to the forum.
If SOIC packages don't have an specific pin 1 marker then they have a chamfer on the side of the package with pins 1-4 (Edit: in this case).
« Last Edit: September 24, 2021, 06:08:06 pm by Gyro »
Best Regards, Chris
The following users thanked this post: loistvan
« Reply #2 on: September 24, 2021, 06:08:02 pm »
Wonderful, indeed! Thank you very much for the fast help!
