Finally got the plywood delivered and installed in the bench. It's shaping up nicely. I am very happy with depth.
Sadly had to abandon idea with non-standard plywood sheets, so no more belly cutouts and extended overhangs.
Current table sheets cut from standard 2.44 x 1.22m size just barely make it depth-wise, but it will do for 2020 until covid situation improves.
Still have lots of work left for refining power routing, lightning and storage areas, but that's fun part and I can resume working on long overdue projects with current setup.
Photos of today's state:
Section 1 - RF and auxilary gear, storage for tools and long-time projects.
Section 2 - main working area, rework equipment, fume extractor, scope, logic analyzer, power supplies, SMUs, microscope.
Section 3 - reference DMMs, calibrators, AC measurement equipment
Equipment layout. Bench have enough room to put full-size full-depth 19" equipment in front of lab gear, which was primary goal for bench depth choice.
Section 4 - calibration standards, temperature chamber box, AC standards. xDevs server on top 3rd shelf.
Storage IKEA boxes for connectors, parts, etc.
Various tools hanging off vertical beams
Underside supports for benches. Can see IP-controlled power switch.
