Circuit ideas? I would like to figure out a way to retain use of the fan speed, on-timer, fan filter reminder button features on the vent hood while installing an inline duct fan in the attic to replace the built-in fan (Miele DA5100D). The new inline Fantech EC motor (FKD 14 XL EC) accepts a 0-10VDC signal for controlling the fan speed.
As a starting point I think I can use the 120V wires from the motor control board (EPL755) that controls 4 levels of fan speed: when wire 1 has 120V, the fan is on the lowest speed, wires 2 and 3 medium speed, and wire 4 receiving 120V drives the motor at the highest speed. Then I would need to convert these signals to 0-10VDC for the EC fan speed control on the new Fantech motor.
In other words, a circuit for conversion of:
120V on wire 1: 2VDC on 0-10V signal wire and 120V power to motor
120V on wire 2: 4VDC on 0-10V signal wire and 120V power to motor
120V on wire 3: 7VDC on 0-10V signal wire and 120V power to motor
120V on wire 4: 10VDC on 0-10V signal wire and 120V power to motor
0V on all 4 wires: no power to the motor
Is there a circuit product that already exists for programming this kind of conversion? Or would I need to make a custom circuit? It would be nice if the four 0-10VDC voltages would be adjustable later (via programming or easy to swap in electronic parts) in case I decide to change the corresponding fan speeds in the future.
