Author Topic: looking for manufacturer or supplier of this part  (Read 5801 times)
Offline SimonTopic starter
  • Global Moderator
    • Simon's Electronics
« on: August 27, 2010, 09:10:43 pm »
Hi guys, an engineer at work has shown me this thermostat that he has got from somewhere and wants to know where we can buy them, pictures attched, if anyone knows anything about these units please can you let me know. if he has the right end of the stick it's an automotive thermostat with and externally connected pot and sensor
Offline Kiriakos-GR
  • Country: gr
  • User is banned.
    • Honda AX-1 rebuild
Re: looking for manufacturer or supplier of this part
« Reply #1 on: August 27, 2010, 10:11:17 pm »
Lots of mystery in the atmosphere ..  :D
Any way , there is some manufacturers that they do small refrigerators ,
mostly for trucks and wheelhouses .
I bet my bubblegum , that its some sort of unique design for such use.
You will not find data that easy, its probably listed in their service manual , but not publicly.
  • Global Moderator
« Reply #2 on: August 28, 2010, 07:02:16 am »
well as a thermostat it should have wide uses, it's just finding who made or marketed in it
  • Global Moderator
« Reply #3 on: August 28, 2010, 09:35:18 am »
Yes Simon you are right !
Thank you for that fountain of wisdom  ;D
Offline Kiriakos-GR
  • Country: gr
  • User is banned.
« Reply #4 on: August 28, 2010, 11:53:29 am »
Yep the monologue some times are the best solution ,
it has to do with the Greek word of "philosophize".
Now you have two choices , built your own , or build your own ..  ;D
Your sample looks to have fixed cut-off value ..
« Last Edit: August 28, 2010, 12:14:57 pm by Kiriakos-GR »
  • Global Moderator
« Reply #5 on: August 28, 2010, 12:10:37 pm »
ah if only they would let me make stuff at work, instead they buy expensive rubbish that was designed by a school boy
  • Global Moderator
« Reply #7 on: August 28, 2010, 12:20:00 pm »
well if the guy has his facts straight it's for a vehicles air conditioning system, a potentiometer plugs into it for regulation
Offline Kiriakos-GR
  • Country: gr
  • User is banned.
« Reply #8 on: August 28, 2010, 12:26:20 pm »
Oh well , with out any schematic at hand , just the part, it will not do much.
The sample looked  special .. from the start.
Offline Kiriakos-GR
  • Country: gr
  • User is banned.
  • Global Moderator
« Reply #10 on: August 28, 2010, 12:44:25 pm »
nah, but we are looking for a proper supplier to supply new ones in quantity, I think he wants to replace some old thermostats with it
Offline Kiriakos-GR
  • Country: gr
  • User is banned.
« Reply #11 on: August 28, 2010, 01:24:46 pm »
Ok , suggestion for another approach  ..
Take it apart , and see if you can copy it ..
The automotive industry , does not use standard parts, always they cooking their parts,
so no one to be able to offer an after-market solution.
And basically its all about quantity , how many he needs ?
If its less than 100 , it does not worth to bother.
« Last Edit: August 28, 2010, 01:27:39 pm by Kiriakos-GR »
  • Global Moderator
« Reply #12 on: August 28, 2010, 01:31:22 pm »
we have opened it, being a thermostat there's not a lot to it. We are not an electronics company and they obviously won't make use of my talents so he wants to find where we can buy this off the shelf. If they were willing to make their own electronics I'd be earning 4X what I am now
