Hi group,
Here is Figure 29 from the Linear Tech application note AN105.
![Current Sense Amplifier INA180 Negative Supply Measurement?](https://www.eevblog.com/forum/index.php?action=dlattach;topic=300866.0;attach=1337585;image)
![](https://www.eevblog.com/forum/projects/current-sense-amplifier-ina180-negative-supply-measurement/?action=dlattach;attach=1337585;image)
The circuit is the same topology that I proposed earlier in this thread.
The circuit uses a zero-drift, chopper-stabilized op-amp in the first position. The offset voltage of this op-amp get multiplied by the gain of the circuit, in this case x100.
The circuit includes some capacitors to reduce the bandwidth.
Protection, if needed can be added, the same way as described by Ian.M and illustrated here:
![](https://www.eevblog.com/forum/projects/current-sense-amplifier-ina180-negative-supply-measurement/?action=dlattach;attach=1336331;image)
Jay_Diddy_B
