Author Topic: What modern MOSFETs for class D?  (Read 16137 times)
Online johansen
Re: What modern MOSFETs for class D?
« Reply #25 on: February 18, 2014, 08:58:25 pm »
I should have rather entitled the thread "What modern MOSFETs for a power inverter".
yup.
btw, i am also looking for the best mosfets for use in a 4 switch 10 to 100 volt input, 22-65 volt output buck boost converter. i'm thinking 200khz but maybe as low as 60khz. 10 amps minimum per phase, surface mounted fets...
« Last Edit: February 18, 2014, 09:01:26 pm by johansen »
Offline dannyf
« Reply #26 on: February 23, 2014, 05:01:14 pm »
You just cannot have a rationale discussion with those guys.
Worse yet, they seem to have acquired this sense of entitlement that just because they have a keyboard and internet connection, they can demand that you talk to them. They get really mad when you refuse to talk to them.
No win situation for us.
Offline SteveyG
  • Soldering Equipment Guru
« Reply #27 on: February 23, 2014, 06:02:02 pm »
I may have a need to construct a class D amplifier whose duty it will be to deliver a 200Vp-p, continuous-level 20 kHz sine wave at 1.9kW input max.* from a single DC power supply rail of 160V. Given supply constraints it will therefore need to be a bridged design.
A switching frequency of 100 kHz will be sufficient. What model MOSFETs should I be considering? I don't think the voltage is high enough to make IGBTs worthwhile.
* With no worse than 1.5kW delivered to the load.
A 20kHz sine wave output with a 100kHz switching frequency? That seems a little low - what's the reasoning behind only 100kHz switching?
YouTube Channel: https://www.youtube.com/user/sdgelectronics/
Use code: “SDG5” to get 5% off JBC Equipment at Kaisertech
Offline dannyf
« Reply #28 on: February 23, 2014, 06:45:33 pm »
The FCC has not approved the license for a 10Mhz 2Kw transmitter yet, :)
« Reply #29 on: February 23, 2014, 06:52:45 pm »
13.8MHz is a good band to transmit in then, no license required provided you keep the harmonics down.
Offline NiHaoMike
    • Facebook Page
« Reply #30 on: February 23, 2014, 10:07:41 pm »
What about switch at 20kHz and use resonant tanks to smooth it into a sine wave?
Offline GKTopic starter
« Reply #31 on: February 24, 2014, 01:18:54 am »
You would need an impractically high Q resonant circuit to handle the grossly non-linear and variable load without severe distortion. Then there is the design issue of coupling to the resonant filter(s) and the attendant problem of amplitude stabilisation.
A “signal” to switching ratio of only 5:1 isn’t really an issue here – adequate “carrier” suppression can be had with more low-pass filter poles. What makes it all impractical is the incompatibility of any practical filter with such a non-linear load.
Bzzzzt. No longer care, over this forum shit.........ZZzzzzzzzzzzzzzzz
