Author Topic: Current limiter  (Read 8631 times)
Offline electronics manTopic starter
Current limiter
« on: February 19, 2014, 09:06:11 pm »
I have a current limiter circuit which consists of a diferential opamp across a current shunt resistor, the output of that opamp goes to a comparator whith a 10 turn pot on the other input, so when the comparator senses that both inputs are more than or equal to one another is turns on and switches on a MOSFET to pull the adjust of an lm317 low to tun the output off and stopp the current, the problem is it oscillates as I expected. This is because as the output is turned off the current drops so the MOSFET switches off, this then means the current increase so the circuit triggers again, my question is how can I make the circuit stay low until the over current stops.
Daniel
follow me on twitter @get_your_byte
Offline tszaboo
Re: Current limiter
« Reply #1 on: February 19, 2014, 10:06:55 pm »
step 1: post schematic.
Re: Current limiter
« Reply #2 on: February 19, 2014, 10:29:00 pm »
sorry its not that great it is just a section from a larger schematic. the output of that opamp just connects to the mosfet
Offline dannyf
Re: Current limiter
« Reply #3 on: February 19, 2014, 10:43:56 pm »
You don't want it to be a limiter; you want it to be a latching switch.
Re: Current limiter
« Reply #4 on: February 19, 2014, 10:45:55 pm »
yeah i suppose but not one that will stay on for too long so not a relay
Offline miceuz
  • Country: lt
    • chirp - a soil moisture meter / plant watering alarm
Re: Current limiter
« Reply #5 on: February 19, 2014, 11:49:08 pm »
I've seen an excellent post on the topic somewhere in electronic.stackexchange.com. Comparator is your problem. I'd suggest putting another opamp instead of comparator and setting a finite gain for that opamp.
Offline T3sl4co1l
    • Seven Transistor Labs
Re: Current limiter
« Reply #6 on: February 20, 2014, 12:03:14 am »
Sounds like a bad recipe for a good oscillator.  (What happens when it exceeds current?  Turns off.  So current is zero?  Let's turn it on again!  Repeat at probably 100kHz or so, or until circuits fry...)
Seven Transistor Labs, LLC
Re: Current limiter
« Reply #7 on: February 20, 2014, 12:21:35 pm »
When dave made this circuit for his usupply he put a unity gain opamp between the differential amp and the high side of the current shunt.
Offline codeboy2k
Re: Current limiter
« Reply #8 on: February 20, 2014, 01:30:09 pm »
Some DC-DC controllers go into a hiccup mode during over current shutdown to avoid this very oscillation problem; granted its still an oscillation, but its very slow :)
Basically, the output switch controller is gated via the hiccup controller. When the hiccup controller turns on the gate and allows the output switch to turn on, and another over-current event is detected , it resets the hiccup timer and the gate turns off. More sophisticated controllers even increase the timeout each time to some max, and reset the timeout to zero after its working again (the cause of the overload is removed).
Re: Current limiter
« Reply #9 on: February 21, 2014, 05:52:56 pm »
could someone sugest a diferent soluution mabe a single chip would be nice but it must be variable whith an external pot.
Offline dannyf
Re: Current limiter
« Reply #10 on: February 21, 2014, 06:19:57 pm »
A potential solution was suggested to you earlier: use a latching switch.
A schmitt trigger that can never be reset for example.
Offline ConKbot
Re: Current limiter
« Reply #11 on: February 21, 2014, 06:26:07 pm »
Or put an inductor in series and make a buck converter that only turns on above the current limit, and make the oscillation useful 8)
Re: Current limiter
« Reply #12 on: February 21, 2014, 06:28:46 pm »
what value would i need.
Offline matkar
  • Country: si
  • Sixty percent of the time it works EVERY time.
Re: Current limiter
« Reply #13 on: February 21, 2014, 07:09:43 pm »
If you're searching for an integrated solution you could find something useful browsing web pages from different chip producers.
Depending on your current / voltage needs you might find something on TI site:
http://www.ti.com/lsds/ti/power-management/power-protection-distribution-monitoring-products.page
These two might do the trick:
TPS2421-1
TPS2421-2
Look at Maxim site for suitable solutions as well: http://www.maximintegrated.com/products/power/power-switching/
Try other producers too.
Offline dzseki
  • Country: hu
Re: Current limiter
« Reply #14 on: February 22, 2014, 02:52:16 pm »
Once I inherited a DIY amplifier and there were some pcbs in series with every voltage lines, as it turned out they were electronic current limiters, I reverse engineered the schematics then, now I loked it up for you, I think it is a very clever circuit, it can be used in both polarity just keep in mind the current flow direction.
HP 1720A scope with HP 1120A probe, EMG 12563 pulse generator, EMG 1257 function generator, EMG 1172B signal generator, MEV TR-1660C bench multimeter
Re: Current limiter
« Reply #15 on: February 22, 2014, 06:45:17 pm »
thanks for that very helpfull.
Offline dannyf
Re: Current limiter
« Reply #16 on: February 22, 2014, 08:11:49 pm »
BD243/BD740 form a PNP; Together with BD749, they form a SCR. BC237 is normally not conducting (that 250p capacitor is very important, :)). As such, the SCR is conducting hard.
As the voltage drop over the scr goes up, the voltage across BC237's b-e junction goes up. Once BC237 starts to conduct, it diverts current away from the "SCR", thus turning it off. Once the scr is turned off, all voltage is drop'd on the whole device, further locking it up.
aka, this is a latching switch.
Because of that, it can be implemented a variety of ways, using SCR, mosfet, solid state relays, etc.
Offline dzseki
  • Country: hu
Re: Current limiter
« Reply #17 on: February 23, 2014, 07:29:25 am »
Thanks for the clear explanation, I also figured out that the little capacitor has a great importance here, but never knew exactly why is this working at all -that's why I drawed the schematics then... And yes, it is latching. Once it goes out you have to remove the power completely to switch on again (I guess shoring in and out would do the trick as well, but this approach isn't very wise if you use it as a fuse)
Offline ohmineer
Re: Current limiter
« Reply #18 on: February 23, 2014, 08:32:52 pm »
If there aren't special requirements, the simplest current limiter that I recall is based on 2 PNP transistors (or 1 PNP + 1 PMOS).
PMOS (Or right PNP) is used as pass transistor.
Current demand can increase until top left PNP BE junction is forward biased.
Therefore, VBE voltage drop over R1 resistor (Sense resistor) set maximum allowed current.
Re: Current limiter
« Reply #19 on: February 23, 2014, 08:41:11 pm »
True that limits current, but the pass element will get mighty hot when it is limiting and dropping most of the supply voltage. the earlier one at least latches into a low dissipation mode when it trips out until the supply is interrupted.
Re: Current limiter
« Reply #20 on: February 23, 2014, 08:51:23 pm »
that is probably the best one i have seen so far, the pass element could be heatsinked, as they are on my BOM already and there will be a fan to keep everything nice and cool.
Offline ohmineer
Current limiter
« Reply #21 on: February 23, 2014, 09:35:54 pm »
Beware! I have just realised that there is a mistake in the screenshot I posted. Iout is not Vcc/R1. The correct expression would be Iout=Vbe/R1.
The drawback of this approach is the change on Vbe with ambient temperature. In any case, I think that there are solutions to compensate for this, although sometimes it does not worth it.
Offline electronic_eel
Re: Current limiter
« Reply #22 on: February 23, 2014, 11:20:26 pm »
If you don't want oscillation, you want
a) latching
    a1) forever until poweroff
    a2) automatic retry after a few milliseconds to seconds
b) foldback
The latching ones completely shut the output off when tripped. The foldback ones always let a little bit of current through. If the current drawn drops below a threshold, the limiter is reset and the full current is available again.
Here is a discussion with some schematics:
http://www.electronics-related.com/sci.electronics.design/thread/196166/electronic-fuse.php
Offline dannyf
Re: Current limiter
« Reply #23 on: February 24, 2014, 12:22:35 am »
Replace Q1 with some leds and they act as over-current indicators.
