Hi everyone,
A while back I found the attached circuit and I can't figure out how to redesign/adapt the circuit. The components being used are relatively old and I 'just' wanted to replace unavailable components with newer ones, otherwise looking for a similar performance. I do not fully understand how the circuit works, but it seems to me that R1 and R2 'somehow' are selected such that the transistors are off when the OPAMP is not pulling any current -- they only switch on once the OPAMP actually starts working. All the calculations I came up with lead to inconclusive results though.
Perhaps someone is able to explain to me how R1 and R2 were computed for the specific example, such that adapting the values for other opamps, and especially transistors, is possible?
Thank you.
