Author Topic: CRT Deflection coils to composite video?  (Read 921 times)
Offline ALearningLadTopic starter
« on: January 17, 2022, 12:54:40 am »
Just had a shower though of can you use a micro controller like a Arduino or raspberry pi to take the signal to the deflection coils. Then translate it into a composite/VGA/whatever video signal. Couldn't see anything like that online. Can someone also explain why you could or could not, thank you!
I will not do anything with this but just want the answer. Not screwing with crts as a novice.
Offline CaptDon
  • Country: is
Re: CRT Deflection coils to composite video?
« Reply #1 on: January 17, 2022, 02:34:15 am »
Answer.....NO! There is no information contained in the deflection sweep voltages. Only the scanning sawtooth waveform.
« Reply #2 on: January 17, 2022, 04:15:54 am »
Ah thanks for the response, haha feel like a dummy now. Does make perfect sense however.
Offline NiHaoMike
    • Facebook Page
« Reply #3 on: January 17, 2022, 04:57:45 am »
Except for vector displays, those use specific waveforms that trace out the desired shape. In the days when those were in common use, the main advantages were better resolution and very high dynamic range.
Offline PKTKS
  • Country: br
« Reply #4 on: January 17, 2022, 03:53:35 pm »
Why bother if the 80/90s decades of VLSI already provided us with
a TON of good  chips to do so reliable?
Some attached here and can be easily found even today..
Paul
Offline PKTKS
  • Country: br
« Reply #5 on: January 17, 2022, 04:01:47 pm »
ALAS...
If you are wondering for something more modern than
simple CRT deflections.. e.g.  resolutions  like multisync monitors..
Try this one still found ... today
Paul
Offline Terry Bites
« Reply #6 on: January 17, 2022, 06:26:54 pm »
I'm about to take a shower myself...
Offline PKTKS
  • Country: br
« Reply #7 on: January 17, 2022, 07:47:03 pm »
hmm almost left aside... if you are going to drive the yoke..
A handy small standalone tip...
Paul
Offline james_s
« Reply #8 on: January 17, 2022, 07:49:56 pm »
It's actually the current through the coils, not the voltage across them that determines the beam position.
Either way you would be much better off just taking the H and V sync signals, and then of course no matter what you do you need to sample the intensity signal to the electron gun to get your video image. If you only looked at deflection current you'd just get a blank raster.
