Hi All,
Just ran into a bit of a weird one and I figured if I was going to find an answer anywhere it was probably going to be here
A new project I'm working on uses a rock-simple half-wave rectified supply, 6VAC in, through a single diode, through a 56R resistor and whacked across a 47uF cap.
For some reason my image didn't embed here *shrug* schematic attached below.
Weirdness ensued when I actually built it. Design uses a 1206 MLCC cap, and when I built it up I was getting all kinds of nasty ripple on the output, tacked a 100uF electro across the MLCC cap and it was fine, dropped that to a 47uF cap, still fine, removed the electro and strapped a second 47uF MLCC cap across the first, ripple was back.
Initially I thought my supplier must've cocked up and shipped the wrong value caps (it'd be REALLY nice if they'd, you know, LABEL SMD caps... never really understood why they don't), but testing them with my meter they came up as 50uF which is well within spec, removed the MLCC cap entirely and tacked a 47uF electro in and we're smooth.
Am I completely off my tree? Is there something fundamental I'm missing here? or do MLCC caps just behave strangely at mains frequencies?
De-confusion much appreciated.
Thanks,
- SRE
