It's been a long time since I became interested in HF, and I thought that maybe it could be time to start working on some basic lab equipment. I have a very old CB transceiver and willing to make it work again.
I thought about starting with a frequency counter, which could work also as a general purpouse one (hence, my requirements so far would be say 1 Hz to 30 MHz, and I'm fairly sure I'm not interested in going beyond that maximum). My plan is, at least on the chart, fairly simple: make a small x10 amplifier, then use D flip-flops (I have some 74ACT74 around), divide the fundamental and count the result with an Arduino.
Unfortunately, I don't even have many means of measuring directly HF signals (since my USB scope is useful up to 15 MHz more or less). Hence, half of the requirements are lacking also to me. I guess 100 mV to 10 V levels are enough to make me tinker with typical parts in a simple transceiver?
At the same time, for another work, while studying JFET on "The Art of Electronics" I found this series-feedback pair, and while testing it for understanding purpouses I tinkered it a bit to work up to around 50 MHz, although with just a 10 dB gain (had to trade between the two).
I'm planning to add two of them in a cascade to make a 20 dB (=x10) gain.
Could this work, at least in principle?
Looking at another book for a DIY transceiver, I noticed the construction of the oscillators involves tuning them down to 100's of Hz (example: something like 10.6985 MHz), hence I'm supposing the best I'm looking for is to read like 29.9999 MHz, so 6 digits in total. Is this possible or am I completely out of touch?
P. S. So far I haven't considered input protection and other stuff.
