Author Topic: Quick question about PCB design  (Read 2670 times)
Offline MyasnikTopic starter
« on: August 22, 2013, 04:44:00 pm »
Just a really quick question.
Let's suppose I would like to build something like this: http://s49.radikal.ru/i125/1112/6d/41c6684a0c56.jpg - it is not my design, I found it on arduino forum. But anyway.
So, let's say I would like to get something like that, but ask some professional to design the pcb for me. Do you know how much such a thing could cost? I can imagine it is not too difficult build. Still, I would rather find a more professional guy rather than creating crap myself :)
Any ideas?
Offline c4757p
  • adieu
Re: Quick question about PCB design
« Reply #1 on: August 22, 2013, 04:44:44 pm »
Your dignity.
« Reply #2 on: August 22, 2013, 04:47:10 pm »
Your dignity.
Haha, it is a good answer and I see your point, but I would appreciate an actual answer :)
upd: let me explain though. I can slap it all together on a breaboard and it would work, but to design for actual use is anoter. I had an idea of building a kit for a very simple handheld powered by AVR and I am just exploring possibilities now :) Which is the reason I am asking.
« Last Edit: August 22, 2013, 04:51:54 pm by Myasnik »
Offline KJDS
    • my website holding page
« Reply #3 on: August 22, 2013, 06:01:02 pm »
Typically between £20 and £50 an hour for a layout agency. A straightforward digital board like that should only take a couple of days at most if there aren't too many new components that need making in the library.
What is vital is that you define the board criteria before you start. Size, layer count, track and gap limits, power planes, connector locations, fixing points, IPC class, soldering method, resist, silk screen etc. You also need to know what they're going to deliver, ie gerber for all layers, some DXF to import into your mechanical system, component position and angles to program the pick and place machine, etc etc.and how much tweaking they'll accept between showing you what they think is a good layout and you adjusting it so you think it will really work.
Then, just when they've spent half a day generating all the manufacturing information and archived the job you will spot a mistake that needs a modification.
Offline Phaedrus
« Reply #4 on: August 22, 2013, 09:45:20 pm »
If you can put it together on a breadboard then you can layout a PCB. It's not that difficult. Download the DipTrace demo and learn how to use it.
"More quotes have been misattributed to Albert Einstein than to any other famous person."
- Albert Einstein
Offline johnnyfp
« Reply #5 on: August 23, 2013, 04:37:22 am »
Something like this ?
Offline pilogger
  • Country: gr
« Reply #6 on: October 07, 2013, 05:42:56 pm »
You can try Eagle also, it worked for me very fast.
Offline Smokey
  • Not An Expert
« Reply #7 on: October 07, 2013, 09:37:54 pm »
So the short answer is:
$18.00 USD
