Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
synchronous counter
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: synchronous counter (Read 1291 times)
Abayomi
Contributor
Country:
synchronous counter
on:
September 09, 2016, 08:35:02 pm »
Am trying to design a circuit that I will use one synchronous decade counter (74192) to control one 7-segment decoder(7447) . This decoder through a 1-4 demultiplexer is used to drive three 7-segments displays individually. The problem am now having is how to hold the voltages at each output of the demultiplexer when switching between outputs
Logged
Abayomi
Contributor
Country:
Re: synchronous counter
Reply #1 on:
September 09, 2016, 09:39:15 pm »
Any help please
Logged
MosherIV
Super Contributor
Country:
Reply #2 on:
September 10, 2016, 09:16:42 am »
There are 2 tecniques:
1 latch the data/pattern into a buffer.
2. Do the multiplexing so fast that the eye sees all 3 displays, relies on persistence of vision.
For more/better help you will have to show a schematic of your circuit.
Logged
David Hess
Super Contributor
Country:
DavidH
Reply #3 on:
September 11, 2016, 02:49:02 am »
Usually the multiplexer drives the 7447 with 4-bit BCD and the 7-segment displays are scanned. This works fine even with 8 displays and the multiplexer only needs to be 4 bits wide instead of 7 or 8 bits wide.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
synchronous counter
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
