Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Is there a 6 pin version of the SRD-05VDC-SL-C relay???
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Is there a 6 pin version of the SRD-05VDC-SL-C relay??? (Read 581 times)
ledtester
Super Contributor
Country:
on:
May 18, 2023, 03:28:53 pm »
On this WiFi relay board:
https://www.amazon.com/gp/product/B09PG1M3M4
there are four SRD-05VDC-SL-C relays. However, looking at the bottom on the PCB those relays appear to have 6 pins whereas all the info I can find on the web suggests that model only has 5 pins. The extra pin is a an addition COM pin on the coil side of the relay.
E.g. a datasheet:
https://www.circuitbasics.com/wp-content/uploads/2015/11/SRD-05VDC-SL-C-Datasheet.pdf
Is the board using genuine Songle relays?
Logged
jm_araujo
Regular Contributor
Country:
Re: Is there a 6 pin version of the SRD-05VDC-SL-C relay???
Reply #1 on:
May 18, 2023, 03:36:05 pm »
I can only count 5 pins in each relay (+3 for screw terminals).
Where are you counting the 6th pin?
Last Edit: May 18, 2023, 03:40:26 pm by jm_araujo
Logged
ledtester
ledtester
Super Contributor
Country:
Reply #2 on:
May 19, 2023, 09:56:06 pm »
Thanks!
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
