Author Topic: Ceramic resonator or crystal ???  (Read 2811 times)
Offline danielksTopic starter
  • Country: my
  • Newbie from Malaysia
« on: August 02, 2011, 04:51:00 pm »
Can anyone suggest to me which one is better ? Ceramic resonator or crystal ? Which is more accurate and which is less sensitive to vibrations.  :-\
Offline Conrad Hoffman
    • The Messy Basement
Re: Ceramic resonator or crystal ???
« Reply #1 on: August 02, 2011, 05:21:41 pm »
I think either is rugged, but the crystal will be more accurate. Ceramic resonators are generally used as a cheaper alternative to expensive crystals. The Q of a crystal will also generally be higher.
alm
  • Guest
« Reply #2 on: August 02, 2011, 10:38:52 pm »
Ceramic resonators are usually a cheap, inferior alternative. One advantage is that their start-up time is faster.
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #3 on: August 02, 2011, 10:58:58 pm »
Ceramic resonators are adequate for all but the most accurate timing requirements - typically 0.5% or so - fine for async comms but not USB or timekeeping.
Resonators are available as 3-terminal devices with built-in caps to reduce component count. Unless you actually need the accuracy, ceramic resonators are generally the cheaper and smaller choice.
Day Job: Mostly LEDs
Alex
  • Guest
« Reply #4 on: August 02, 2011, 11:06:05 pm »
danielks,
more factors should be considered when selecting oscillator components even for basic projects. For example, ceramic resonator might not work at all if sufficient drive level cant be provided.
An overview with good tips can be found here:
http://ww1.microchip.com/downloads/en/devicedoc/osilator.pdf
with a more detailed discussion here:
http://ww1.microchip.com/downloads/en/AppNotes/00826a.pdf
Reading these two will answer your question and more.
