Author Topic: Paschen's law - spark gap distance at high pressures  (Read 1354 times)
Offline honeybadgerTopic starter
  • Country: cz
« on: August 06, 2019, 07:24:30 pm »
I "need" to know breakdown voltage of air at 8 bar pressure. I spent 2 hour of googling and found nothing. I just need a simple graph of "air breakdown voltage VS air pressure".
There is a lot of these charts: https://en.wikipedia.org/wiki/Paschen's_law#/media/File:Paschen_curves.svg  I don't understand them... vertical scale is in "V" , not "V/m".
And then there is the Paschen's law... can anybody understand that? Where can I find all these constants?
Offline mikerj
Re: Paschen's law - spark gap distance at high pressures
« Reply #1 on: August 06, 2019, 07:43:24 pm »
Check the horizontal scale pd i.e. pressure multiplied by electrode separation.
The following users thanked this post: honeybadger
  • Country: cz
« Reply #2 on: August 06, 2019, 10:49:21 pm »
mikerj: thanks, it makes sense now.
So if "pd = pressure x electrode gap" remains constant -> this means breakdown voltage must remain constant. Twice the pressure -> 1/2 electrode gap = same breakdown voltage.
Is it really this simple? :palm:
If at 1 bar (absolute) I need 3kV per mm -> at 10 bar (absolute) I would need 3kV per 0.1mm, which is 30kV/mm. Am I correct?
Offline floobydust
« Reply #3 on: August 07, 2019, 05:47:58 am »
I thought Paschen's law is more about the non-linearities on the low end (low pressures, very small µm gaps) but larger gaps/higher pressures behave more linearly.
8 bar is around 116 PSI or close to automotive compression stroke pressure. You can see this on sparkplug testers that take shop compressed air and apply that to a chamber with a sparkplug mounted in it. 1mm spark gap is around 30kV, although turbulence, electrode geometry, ozone, polarity matter.
Offline Le_Bassiste
An assertion ending with a question mark is a brain fart.
Offline Plasmateur
« Reply #5 on: August 08, 2019, 01:53:23 pm »
Is this for AC or DC? For much higher frequencies, Pachen's curve will be modified.
Check out page 23 of the PDF here: https://apps.dtic.mil/dtic/tr/fulltext/u2/1018515.pdf
