Author Topic: Battery NTC calibration formula help  (Read 1353 times)
Offline PsiTopic starter
« on: November 17, 2015, 08:19:51 pm »
Is anyone able to help me rearrange these two formula to work the other way. I want to figure out what the Rcold and Rhot values will be for any given Rlo and Rh.
I've tried a few times with wolfgram alpha but don't seem to be getting consistent results.
Vcold is 1.99
Vhot is 0.75
Vin is 5
« Last Edit: November 17, 2015, 08:21:55 pm by Psi »
Offline eneuro
Re: Battery NTC calibration formula help
« Reply #1 on: November 17, 2015, 09:09:18 pm »
I've used 1% NTC with 1% 10k in this configuration and by using manufacturer given 3380K for this part NTCM-HP-10K-1%  -55÷125°C; 50mW I;ve made look up table for MPU, so If I wanted I could read directly MPU ADC value and hadrcode in MPU to create desired logic and now I can forget about opamps, but using calculator shown above where I've checked experimantal data by making measurement of NTC resistance at known room temperature using another termometer, voltages thesholds could be estimated, to be able use comparator instead of MPU with ADC  ;)
More about this look up table method and link to this quite nice NTC calculator starting from here:
NTC Thermistor resistance (Li-Ion Charging) ...
12oV4dWZCAia7vXBzQzBF9wAt1U3JWZkpk
“Let the future tell the truth, and evaluate each one according to his work and accomplishments. The present is theirs; the future, for which I have really worked, is mine”  - Nikola Tesla
