Was wondering if anybody knew a connector range that work board-to-board, wire-to-board and wire-to-wire all at the same time? I haven't found one. I'm guessing some creative thinking will be needed here.
- ideally polarised
- 1A or more,
- small size, say 1.5 to 3.5 mm pitch (or max current 5A as a gauge of style)... stardard 2.54mm dupont/mini-pv size would be great.
- 4 poles or more
current notes:
- 2.54mm bump/polarised dupont/mini-pv housings with bump/polarised nearly work. However wire-to-wire has no proper female housing part, male/female crimp pins are used, which isn't ideal.
- I like Molex SL, but no female header for board-to-board. I guess I could probably use standard (unpolarised) 2.54mm pitch headers
Cheers
