Author Topic: AD574 Precision Voltmeter Schematic  (Read 1604 times)
Offline Chris56000Topic starter
« on: May 10, 2017, 03:22:23 pm »
Hi!
I get, in my job, quite a number of industrial panels for repair, in which the AD574JN pops up, and as remaining supplies of this device are into three figures,
I have been looking for a circuit I can make to test it!
I have came across a number of links for a "High Precision AD574 Voltmeter Schematic that all appear to be this:-
http://8085projects.info/ad574-based-high-precision-digital-voltmeter-circuit.html
but I can't seem to find any source or hex to go with it!
Does the Microcontroller used here need to be programmed, and has anyone come across the original article that had the code please?
I found this attachment, but it's password protected and the site "developer downloads"
http://developerdownload.info/958211/
I got it from  gives no indication of what the password is or how to register for it!
Any ideas?
Chris Williams
It's an enigma that's what it is!! This thing's not fixed because it doesn't want to be fixed!!
Offline Kleinstein
Re: AD574 Precision Voltmeter Schematic
« Reply #1 on: May 10, 2017, 05:09:56 pm »
The voltmeter circuit will likely only use a few of the input channels and also likely not the full functionality. So one would need a different software to do a more thorough test anyway. For a test it also takes something like a test signal - e.g. a slow ramp or a reasonable quality triangle and maybe a few fixed values.
