I want to use the ESP32-S3 ADC which proudly boasts that it can do 100ksp but I can't seem to work out how to practically use that because of bandwidth limitations.
The docs say you should ideally connect a 100nF ceramic capacitor to the ADC pin (
source).
However, its also well known that the ADC pins will glitch low for 60uS on startup (
source).
That low glitch would require an impedance of roughly 500ohms to avoid a significant over-current situations.
But an impedance of roughly 500ohms would make a low-pass filter with the 100nF capacitor for a bandwidth of roughly 3kHz.
What gives? Can I drop the capacitor to get more bandwidth at the expense of noise?
