Author Topic: Where to get 3x2 IDC wire to board connector inm2mm pitch?  (Read 657 times)
Offline DTJTopic starter
« on: March 10, 2022, 11:28:08 am »
Has anyone any ideas on who makes a 6W (3 × 2 row) ribbon cable IDC connector in 2mm pitch?
I've searched most places I can think of and can not find anything.
I have an IP67 panel mounting USB connector that has the 3x2 @ 2mm hole pattern on a small PCB sticking out the back.  Soldering individual wires on hundreds of these will be a PITA.
Someone must make one, even a 4x2 at a pinch.
This style but in 3x2 @ 2mm pitch.
https://encrypted-tbn0.gstatic.com/images?q=tbn:ANd9GcTs4MC1BkiyjleEhuwPbB3jtMprZLL8wjJAuQ&usqp=CAU
Thanks.
« Last Edit: March 10, 2022, 11:29:50 am by DTJ »
Offline tooki
Re: Where to get 3x2 IDC wire to board connector inm2mm pitch?
« Reply #1 on: March 12, 2022, 01:49:51 pm »
Took me 2 minutes to find these on Digi-Key*: https://www.digikey.ch/en/products/detail/amphenol-icc-fci/89361-106LF/1535464
That one’s in stock, 3 more are out of stock at the moment, and 13 other types available for special order. Match to a common 2mm header.
*Connectors > rectangular connectors, free hanging > filter by part status (active), pitch (2mm), positions (6), rows (2), contact type (female) and cable type (ribbon).
« Last Edit: March 12, 2022, 01:54:22 pm by tooki »
The following users thanked this post: DTJ
Offline gamalot
  • Correct my English
    • Youtube
« Reply #2 on: March 12, 2022, 02:24:42 pm »
The only one I can find that matches your requirements is the Samtec TCMD-03-01, unfortunately none of the distributors have it in stock.  :-//
https://octopart.com/tcmd-03-01-samtec-16812359
« Reply #3 on: March 14, 2022, 05:44:05 am »
Thanks Tooki. I found those we have limited space so need the direct solder to board style.
« Reply #4 on: March 14, 2022, 05:45:32 am »
Thanks Gamalot - you are on the money with that one. I'm conversing with Samtec now about getting some. They will have some in stock in the near future! ;)
Cheers.
