Let me add a few things to the discussion.
Reference:
https://www.schaffner.com/fileadmin/media/downloads/application_note/Schaffner_AN_CISPR17_Measurements_E8.pdfThis talks about the issue with filters measured in a 50
![Ohms \$\Omega\$](https://www.eevblog.com/forum/Smileys/default/omega.gif)
/ 50
environment and then used in a 0.1
100
environment.
0.1
100
is correct for Differential Mode emissions. The LISN inputs are in series.
0.1
25
is correct for Common Mode emissions because the LISNs are in parallel for CM inputs.
Inductor Model
Here is the curve from the datasheet:
![Conducted emissions issue with multiple Mean Well AC/DC converters](https://www.eevblog.com/forum/index.php?action=dlattach;topic=244077.0;attach=1005559;image)
From the datasheet we know:
The nominal inductance is 700uH
The Rdc = 24m
From the curve we know that the SRF is around 3MHz
We can calculate parallel capacitance as 10pF
We need to add a parallel resistance to set the maximum attenuation, at resonance, to be 32dB in the 50
test circuit:
![Conducted emissions issue with multiple Mean Well AC/DC converters](https://www.eevblog.com/forum/index.php?action=dlattach;topic=244077.0;attach=1005549;image)
If I run the model and plot V(vin)/V(vout) I can get the attenuation of the CM choke per CISPR 17 in a 50
50
test circuit:
![Conducted emissions issue with multiple Mean Well AC/DC converters](https://www.eevblog.com/forum/index.php?action=dlattach;topic=244077.0;attach=1005551;image)
Given the simplicity of the model, this is pretty close to the datasheet.
Application Circuit
The CM choke forms a filter with the Y caps. The X cap connects the two lines in parallel, so the Y capacitors are considered in parallel.
If we believe Schaffner, and accept that noise source is 0.1
and you trust me that a pair of LISNs presents 25
to CM signals.
Then the application circuit can be modeled:
![Conducted emissions issue with multiple Mean Well AC/DC converters](https://www.eevblog.com/forum/index.php?action=dlattach;topic=244077.0;attach=1005553;image)
The result from running the model shows how the CM choke works with the Y-caps to create an effective filter:
![Conducted emissions issue with multiple Mean Well AC/DC converters](https://www.eevblog.com/forum/index.php?action=dlattach;topic=244077.0;attach=1005555;image)
Y-cap location
The location of the Y-caps depends on if you are stopping emissions or improving immunity.
In a power supply, normally the plan is to reduce emissions, so the Y-caps should be located on the input of the power supply, the mains side of the CM choke.
Here are the modelling results showing the impact of having the Y-caps on the wrong side:
![Conducted emissions issue with multiple Mean Well AC/DC converters](https://www.eevblog.com/forum/index.php?action=dlattach;topic=244077.0;attach=1005557;image)
In the diagram of the DCP405 the Y-caps are on the wrong side of the CM choke.
Regards,
Jay_Diddy_B
