> Can you share more about the design? I noticed you included an attenuator at the in & outputs; I guess to get a better impedance match.
sure can, if you send me your email, i send you the gerber zip, so you can order this design,
here is a youtube link to a detailed explainer about this :
https://youtu.be/y79nOd8GLWIi keep one with 0R on the centre, and then use that to calibrate the analyzer tracking generator, for a flat line,
now swap to the tester one, where an inductor or capacitor is mounted,
you can also use this to trim filter designs for best performance, see how different caps in parallel behave (parallel resonance)
the two 5dB attenuators each side of the DUT, is to keep the NA / SA-TG tester in good match,
and to feed the test area with a resistive load from both sides,
else you create resonance problems with the cable length, different cables would then create different results,
this methode is much better :-)
this PCB is flat to over 3GHz. i also design RF stuff, so i need to see how my parts perform.
