If there is no space for normal test points, or if one has forgotten to add a specific test point, an alternative could be to use a component pad
as the test point. I particularly think of probing the soldered side of a capacitor/resistor/ferrite bead 0805/0603 pad.
There are some potential issues I can think of:
1. Capacitor cracking due to too high force while the pogo pin presses against the component.
2. Solder flux residue which may prevent good contact.
I would guess the safest parts to allow for test probes are 0805 (and bigger) resistors and ferrite beads...
What first comes to mind is using a flat, larger, tip with small sharp teeth (not the conical tip style) pogo pin in order to evenly distribute the force.
Has anyone done this, and what is your experience?
