I'm looking to replace an ESD for CANBUS with a more generic product. PESD1CAN is two bidirectional TVS and comes in SOT23, and if possible I would like to replace it with two generic SOD523 or similar (more flexible in tight layout).
I'm not sure how to read the PESD1CAN datasheet, and choose a "identical" or better spec'ed TVS.
Like "RATED STAND-OFF VOLTAGE", should I choose exactly 24V or is higher also fine? And with the "MINIMUM BREAKDOWN VOLTAGE", can I go lower? And "MAXIMUM CLAMPING VOLTAGE", should I choose the same or higher? Etc.
How to choose?
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
