Author Topic: Question about obtaining the input network transfer function of an inverting OPA  (Read 777 times)
Offline opa627bmTopic starter
Hi all,
I am trying to review some of the fundamentals that has been long forgotten since school.
by reading this
https://peer.asee.org/a-method-for-obtaining-the-transfer-function-of-inverting-and-non-inverting-op-amp-circuits-based-on-classical-feedback-theory.pdf
I can follow the non-inverting section pretty well, but when comes to the inverting section:
page 8,
The input network transfer function is defined as - RF/(RF+RA), and feedback transfer function still RA/(RF+RA)
Since now Vin is a term in the equation,
Vi-Vout/(RA+RF) = Vi-V_ /RA = V_ - Vout)/RF
I know the gain is simply  -RF/RA , but i am trying to make sense of it.
any input will be appreciated, thank you !
My question is now did the author come out with - RF/(RF+RA) as for the input network transfer function..
thank you !
Regards,
Li
« Last Edit: March 24, 2021, 04:10:21 am by opa627bm »
Offline ledtester
If we naively translate the inverting op-amp circuit to a transfer network we might begin with something like:
1201314-0
The key to figuring out what goes in the ? ? ? area is to realize that the formula for the inverting input is
\text{Inverting input} = \frac{v_i R_f + v_o R_a}{R_a + R_f}
and so we can fill in the ? ? ? as follows:
1201318-1
Note how the minus sign in the \$v_i\$ transfer function is canceled by sending it the minus input of the new summing node.
Now we can short circuit the top summing node because we are just adding 0 -- i.e. the output of the lower summing node can go directly to \$G(s)\$ -- and that leads to the diagram in the paper.
Correction: We can short circuit the lower summing node to \$G(s)\$ with a multiplier of -1 since the lower summing node goes the negative input of the upper summing node.
« Last Edit: March 24, 2021, 07:57:26 am by ledtester »
The following users thanked this post: opa627bm
Hi Ledtester,
thank you so much for the reply.
I can get the V_ transfer function using superposition.
but how to add the correct sign (input network (some people call it alpha ) is negative) The feedback network (some people call it beta ) ,
how to separate the combined term correctly into alpha and beta and with correct sign ?
Thank you for the help!
Regards,
Li
PS: sorry the pic I attached is rotated for some reason, from my viewer it is in the correct orientation.
Offline ledtester
I'm not sure exactly what you're asking about, but perhaps this will help...
The equation \$V_A = V_B B + V_C C\$ is the same as this network:
1201856-0
Of course, you can decide to put the minus sign on C rather than B if you also switch the inputs to the summing node.
You have:
\begin{align}
V &= \frac{ V_{\text{IN}} R_F + V_{\text{OUT}} R_A } { R_F + R_A } \\
   &= V_{\text{IN}} \frac{R_F}{R_F+R_A} + V_{\text{OUT}} \frac{R_A}{R_F+R_A} \\
\end{align}
So set:
\begin{alignat*}{2}
V_B &= V_{\text{IN}},   &B = \frac{R_F}{R_F+R_A} \\
V_C &= V_{\text{OUT}}, &C = \frac{R_A}{R_F+R_A} \\
\end{alignat*}
and apply the diagram.
Hi Ledtester,
Sorry for not making my question clear.
I have used PDF this time, that should me the orientation correct.
My question is, how to map the terms in the V_ transfer function with correct sign to the input network transfer function and feedback network transfer function. and how to determine the correct sign on the summing block (+) and (-)
Regards,
Li
Offline ledtester
Both of these are equivalent - you can decide to use either one. Note carefully where the + and - signs are on both the transfer functions and the summing node inputs.
1202004-0
