Author Topic: cheapest way of turning on many optocouplers based on a -+ common signal  (Read 1478 times)
Offline ali_asadzadehTopic starter
I know it may sound very simple, I should use a bridge rectifier, :) but as I have only a common ground to about 1024 LED’s and it can be either positive or negative, since in some systems the common signal is ground or Positive ground, do we have a better way of avoiding 1024 individual diode bridges, see the sample circuit.
ASiDesigner, Stands for Application specific intelligent devices
I'm a Digital Expert from 8-bits to 64-bits
Online ajb
Re: cheapest way of turning on many optocouplers based on a -+ common signal
« Reply #1 on: December 03, 2018, 03:09:36 pm »
Use AC input optocouplers?
« Reply #2 on: December 03, 2018, 03:19:02 pm »
Thanks, do you have any part number with similar prices to normal ones?
Offline spec
  • MALE
« Reply #3 on: December 03, 2018, 11:14:57 pm »
Hi ali_asadzadeh
You say that the input voltage can be either positive or negative, depending on the system feeding the LED matrix. At any one time will there be a mixture of positive and negative inputs, or will they all either be positive or all negative- hope that makes sense :)
Does the LED matrix have any power of its own, or could a small power supply(5V @100mA say) be added- perhaps a battery (neither to power the LEDs).
« Last Edit: December 03, 2018, 11:21:57 pm by spec »
Offline DaJMasta
    • medpants.com
« Reply #4 on: December 03, 2018, 11:16:26 pm »
I'm also sort of confused about what's going on, you say it's a matrix of LEDs but it's optocouplers?  Are you actually sending data with something like a differential input signal, or are you just trying to drive a lot of LEDs?
What is the device and what do you want to make it do?
Offline spec
  • MALE
« Reply #5 on: December 04, 2018, 12:48:17 am »
The way it reads is that they are LEDs inside an optocoupler. For the purpose of answering the OP's question we don't really need to know anymore in that area. :)
« Reply #6 on: December 04, 2018, 07:56:56 am »
Thanks, we have 1024 optocouplers , so I meant the led inside the optos ;)
We have one common signal and 1024 individual inputs, the inputs should be configured so that they could detect a positive or a negative common signal, because the customer have different sites with different common signal configuration.
« Reply #7 on: December 05, 2018, 05:46:02 am »
I have a new Idea! maybe Padauk MCU's come in handy :) ;)
