Author Topic: Chip manufacturer from logo?  (Read 6330 times)
Offline robstarTopic starter
« on: May 13, 2013, 04:50:56 am »
Anyone know who this is?
It's labeled "U1" and from its placement, i'm guessing it's a voltage regulator.
Thanks!
--Rob*
Offline marshallh
    • retroactive
Re: Chip manufacturer from logo?
« Reply #1 on: May 13, 2013, 04:59:50 am »
Don't recognize, couldnt tell from first glance... Probably an asian fab that is cheap.
What is the background on the rest of the device?
Verilog tips
BGA soldering intro
« Reply #2 on: May 13, 2013, 05:03:18 am »
Cheap is totally the direction to be thinking. The device is a motion-sensing lightbulb fixture that i'm gutting for the PIR sensor. I can't find a datasheet for that either, and was hoping to infer its supply voltage from this chip.
Offline marshallh
    • retroactive
« Reply #3 on: May 13, 2013, 05:08:11 am »
Well, it could be a fixed linear reg or an adjustable one. Adjustables generally have a coupel resistors sitting next to it.
Look up any generic LDO from National, Linear, NXp, etc in SOT-89 package.
Best to check while running with a meter.
Pinning could be: GND, Vin, Vout but could just as well be several other combos (quite annoying)
Verilog tips
BGA soldering intro
« Reply #4 on: May 13, 2013, 06:36:26 am »
Yeah, though this is designed to run off the mains using a light bulb socket, so "while running" will mean a more elaborate operating theater than usual.
Offline peter.mitchell
« Reply #5 on: May 13, 2013, 07:15:27 am »
can we see the whole board, so we can rule stuff out ect? see where it sites "in situ"
« Reply #6 on: May 13, 2013, 07:51:00 am »
Sure! Here's the whole thing, just cracked open (didn't have the right screwdriver... oh well ;)
Here's the top of the board with the PIR and leads that would go to the load (a bulb):
Here's the bottom of the board with various ICs (the original mystery one is U1 on the left) and the leads that connect to the mains:
« Reply #7 on: May 13, 2013, 07:56:59 am »
All the example circuits on the web for the BISS0001 show it and the PIRs it reads as being 5VDC devices, e.g.: http://www.e-voron.dp.ua/catalog/016873 has:
Offline amyk
« Reply #8 on: May 13, 2013, 10:50:10 am »
http://md-ic.com.cn/datasheet/MD53XX_C.pdf
MD5336 3.6V 500mA LDO
Company: Shanghai Mingda Microtronics Co., Ltd.
« Reply #9 on: May 13, 2013, 03:51:33 pm »
Thanks, amyk! Googling for "biss0001 3.6v" (or "biss0001 3.3v") turns up plenty of non-5v "BISS0001" chips. Anyone know the mfr of this one? Looks like a white circle with the top half of an "S" in black on it. (Or maybe that's a final lowercase sigma? http://en.wikipedia.org/wiki/Sigma  Or a stigma? http://en.wikipedia.org/wiki/Stigma_%28letter%29)
« Last Edit: May 13, 2013, 03:55:27 pm by robstar »
