Author Topic: Cheapest way to get higher density PCBs  (Read 1441 times)
790037918
  • Guest
« on: April 20, 2016, 02:57:38 pm »
NOTE: This message has been deleted by the forum moderator Simon for being against the forum rules and/or at the discretion of the moderator as being in the best interests of the forum community and the nature of the thread.
If you believe this to be in error, please contact the moderator involved.
An optional additional explanation is:
« Last Edit: April 24, 2016, 12:07:48 pm by Simon »
Offline IconicPCB
Re: Cheapest way to get higher density PCBs
« Reply #1 on: April 20, 2016, 08:01:21 pm »
You want to play with professional grade components You need professional grade interconnect system ( read PCB).
Your other option is to mock up bga chips from lego blocks and use a phenolic single sided PCB.
Quality is like oats.
Once they have been through a horse they cost a little bit less.
Offline suicidaleggroll
« Reply #2 on: April 20, 2016, 08:10:03 pm »
I don't know what's available in China, but in the US OSHPark has 4-layer boards with 5 mil trace/space and 18 mil vias (10 mil drill + 4 mil AR) for $10 per square inch for a set of 3.  That should be fine for 0.8mm pitch BGAs, unless you need a bunch of impedance controlled traces, in which case the 4-layer and pre-preg thicknesses start to fight you.  I can't imagine you are unable to beat those prices in China.
