Author Topic: Cheapest TQFP-100 packages - For aligning Pick and Place Machines.  (Read 3272 times)
Offline mrpacketheadTopic starter
  • D Size Cell
Aligning a Pick and Place machine can be quite a nightmare, and you need to repeated placemetns to check and veritfy that everytnign is good.  It gets more critical the bigger the parts are, as small rotatonal shifts can result in big misplacments.
I'm looking to buy the lowest cost TQFP-100 packages, preferably 0.5mm pitched.. I dont' care what they are,  they are only intended for testing the PnP.. using $10 microprocessors is an expensive way to do it.
Any suggestions
Offline sleemanj
  • Professional tightwad.
Re: Cheapest TQFP-100 packages - For aligning Pick and Place Machines.
« Reply #1 on: May 16, 2017, 01:43:29 am »
Aliexpress, search TQFP100, Free Shipping, sort by price ascending.  About $1.30 USD/ea is the cheapest.  Sort by price descending to see larger lots, but again looks like about 1.30/piece is about the limit.
The following users thanked this post: mrpackethead
Offline alex89
« Reply #2 on: May 16, 2017, 01:47:14 am »
You can buy dummy components, these are made for soldering practice and are very cheap.
Offline BrianHG
    • LinkedIn
« Reply #3 on: May 16, 2017, 01:52:52 am »
This is the cheapest I've seen:
http://www.semiconductorstore.com/cart/pc/viewPrd.asp?idproduct=57688&utm_source=findchips&utm_medium=fccpcref&utm_campaign=SFFCOC&utm_term=LAMXO256C-3TN100E
Digikey also sells them...
I wonder what you can do with an automotive grade $1.98 100 pin PLD with internal flash?
Offline james_s
« Reply #4 on: May 16, 2017, 04:38:06 am »
These are even cheaper, they're actually useful parts assuming they're usable and not fake. If they are fake that's even better for this application.
http://www.ebay.com/itm/IC-EPM240T100C5N-TQFP100-ALTERA-NEW-GOOD-QUALITY-/351494421419?
Offline calexanian
    • Alex-Tronix
« Reply #5 on: May 16, 2017, 04:44:03 am »
I like how they say "Good" quality. If those are real passed QC chips I would be shocked! Perfect for your purposes though. You have to be careful the pins are not tarnished or some other such thing. Could give you false negative results in your placement and soldering tests or something.
Charles Alexanian
Alex-Tronix Control Systems
Offline james_s
« Reply #6 on: May 16, 2017, 04:50:01 am »
You can never tell with that Chinese stuff, I've gotten junk and I've gotten stuff that was just fine. I have a bunch of little Altera FPGA dev boards that cost less than the bare IC from US distributors and they work just fine. I suspect the chips used on those are surplus genuine parts, no way to know with these. They're cheap enough that you could buy a couple and evaluate their suitability..
  • D Size Cell
« Reply #7 on: May 16, 2017, 05:15:30 am »
Thanks.. did'tn even think about my good freind aliexpress..    Just bought 30 pces of EPM3128ATC100 EPM3128ATC100-10N TQFP100 for $30USD includ shipping.  Perfect.. :-)
« Last Edit: May 16, 2017, 05:22:54 am by mrpackethead »
Online Kjelt
« Reply #8 on: May 16, 2017, 10:25:56 am »
Yes google at the name "Amkor" and place an "A-" in front of the packagename and you find the dummy components of this firm.
"Amkor A-TQFP100"
I am not sure if they are cheaper than obsolete components  ;D
