Author Topic: selecting a signal connector  (Read 722 times)
Offline kuonTopic starter
« on: February 09, 2021, 04:44:59 am »
I know this has been asked a million times, I read many things, but I still would like your advice on a connector selection.
I want a connector to connect a load cell to a PCB. I need
- 5 circuit (4 + cable shield actually)
- good signal integrity as I am measuring uV
- easy to mate/unmate without tools
- full smt
- audible click on assembly
- right angled
- 1.5-2.5mm pitch
- ambient temperature and no vibration, so no requirements on this side
So far I have found:
- molex nano fit
- molex micro lock
- molex micro one
- molex clik
- hirose DF3EA
But I don't know which to choose.
Offline tooki
Re: selecting a signal connector
« Reply #1 on: February 09, 2021, 07:06:10 pm »
A key spec in small connectors is how many insertion cycles it needs to support. Some connectors can handle dozens or hundreds of cycles, others are pretty much designed to be plugged once and that’s it.
« Reply #2 on: February 09, 2021, 07:35:07 pm »
A dozen of cycle is enough to maintenance. But not "once". I tried some JST connectors, but they are nearly impossible to unplug properly.
All the connector I selected have a durability of 30 cycles, except nanot fit which has a 50 cycle option.
« Last Edit: February 09, 2021, 07:53:21 pm by kuon »
Offline tooki
« Reply #3 on: February 10, 2021, 05:12:54 pm »
JST has dozens of different small signal connectors. They vary dramatically in ease of insertion/removal. I’m a big fan of JST XH, as it uses the “folded beam” contact style that is very robust, but is cheap and reasonably compact. But there are also ones with latches (which provide positive retention, but comparatively easy removal).
That hirose series looks nice, as a complete wire to board, wire to wire, and board to board system.
