Well, as you have
removed or at least moved around some of the insulation, it's impossible to say from a single photograph whether it was originally good or not. That's why I only could say that using several types of insulation is a good sign, but a good sign doesn't equal good end result. But only you have the knowledge how it was put together before the destructive teardown, so we need to trust your analysis, which would require taking you seriously first, which is a bit difficult to do for the following reasons:
- As this is the worst soldering you have ever seen, that clearly means this is one of the first electric or electronic products you have ever opened -- you don't need to do too many teardowns to find actually horrible solder job, namely cold joints, or joints that have not flown properly at all due to oxidized surfaces.
Very typical in low-cost Chinese products, but you have clearly not seen it. (For example, a Chinese hot air station I examined connected the Protective Earth wire with a cold solder joint from a single strand, they had managed to do a solder work that had tens of ohms of resistance! I call that a special ability!)
- And, yes, you got me there! Of course I work for some random no-name Chinese battery manufacturer
! Are you kidding me
You know, you post something, I analyze it just for fun. I use whatever information is available. Not much was this time. I'm not your feelgood circlejerk robot, so I skip your analysis and do my own, I don't exist to confirm your bias. I didn't draw
any conclusions about the quality, and will not, because not enough data is available for that. I can always guess that
most likely, the quality is horrible shit and the product is dangerous, as you say; that would be fairly typical in this product segment.
But on the surface, based on that teardown photo, it looks like any other Chinese RC battery, some are more dangerous than others, and I have seen some that are a lot worse, namely soldered series connections instead of welded; and really bad solder job.
