I wouldn't have bothered... that's what ... 18 cells?
Ideally, you would add some kind of fuel gauge IC to know how much energy is still left in the cells, and for example if the amount is below some threshold, run the cells down, discharge them, and only then charge them up.
Not sure how I'd do it .. maybe I'd have the battery arranged in 3 groups of 6 cells, or 6 groups of 3 cells that could be charged in parallel (have some solid state relays or some way of separating the groups when you plug battery in charger)
This way you'd be able to charge the groups with 5v (for the 3 cells in series) or 9v or higher for the groups of 6 cells
You'd probably be better off with a pack of LifePo4 cells ... with 3.6v charge voltage, you could have 6 in series and charge them directly with a 20-21v power adapter (charge voltage would be up to 3.6v per cell, 6 cells x 3.6v = 21.6v ... charging them to lower maximum voltage will increase their life)
