Author Topic: Nuvistors – teardown / pictures  (Read 1796 times)
Offline mister_rfTopic starter
« on: January 18, 2023, 07:40:54 pm »
The 7586 Nuvistor type, manufactured by Hitachi.
RCA introduced the Nuvistor in 1959 as a miniature, rugged, metal-ceramic enclosed vacuum tubes, as a serious competition for the transistor.
The 7586 is a medium mu triode.
The following users thanked this post: SeanB, edavid
Re: Nuvistors – teardown / pictures
« Reply #1 on: January 18, 2023, 07:41:44 pm »
6С51Н-В (6S51N-V), equivalent to the 7586 Nuvistor.
Manufactured in the former Soviet Union,1975.
Offline SiliconWizard
« Reply #2 on: January 18, 2023, 07:48:01 pm »
Cool vintage stuff.
Which makes me think, did you know about the Korg Nutube? It's still available and can be fun to tinker with for people willing to design small vacuum-tube-like preamps and the like, in a much more convenient form factor. Not cheap though.
https://www.korgnutube.com/en
The following users thanked this post: 741
« Reply #3 on: January 18, 2023, 07:49:10 pm »
The 7586 Nuvistor type, manufactured by Philips in USA.
The following users thanked this post: blackdog, SeanB, edavid, yo0, globoy
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #4 on: January 18, 2023, 07:56:56 pm »
This is a seriously cool series of photographs. Thank you for sharing!
Offline james_s
« Reply #5 on: January 19, 2023, 01:56:03 am »
I wonder sometimes where vacuum tube development would have gone had transistors never been invented. I suspect we'd see some forms of vacuum integrated circuits at some point, constructed similarly to VFDs, and vacuum tubes the size of modern transistors or smaller.
The following users thanked this post: oz2cpu
« Reply #6 on: January 19, 2023, 02:16:45 am »
Did you take a look at the Korg part I mentioned? It's exactly that. Based on a VFD.
Offline CatalinaWOW
« Reply #7 on: January 19, 2023, 02:28:41 am »
Thanks for the pictures, particular the internal views.  I had never paid attention to construction and assumed they looked like smaller versions of their predecessors, just as the miniature base tubes strongly resembled their octal predecessors.  What a leap the nuvistirs we're.
Online BrianHG
« Reply #8 on: January 19, 2023, 02:30:35 am »
Here: https://www.extremetech.com/extreme/185027-the-vacuum-tube-strikes-back-nasas-tiny-460ghz-vacuum-transistor-that-could-one-day-replace-silicon-fets
Offline james_s
« Reply #9 on: January 19, 2023, 03:04:19 am »
I remember seeing something about that when it came out. I was thinking something on a smaller scale though, as in complete flip flops and op amps in a package roughly the size of a DIP IC, and power tubes in a larger VFD-like package like that.
« Reply #10 on: January 19, 2023, 03:38:20 am »
Dunno if that could be miniaturized that much. Due to the structure having to withstand the vacuum.
I'd be curious to test those Korg things anyway. I've never designed any tube-based circuit, so that could be an occasion.
Online TimFox
« Reply #11 on: January 19, 2023, 03:50:20 am »
An important detail about Nuvistor manufacture:
"Normal" tubes were assembled, sealed into a glass envelope, and then evacuated.
Nuvistors were actually assembled inside a vacuum chamber, including brazing the ceramic into the metal housing.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #12 on: January 19, 2023, 04:02:52 am »
Well, physically speaking, semiconductors are inevitable.  On the most basic level, they work by promoting charge carriers across a potential barrier, and magic happens; in vacuum, this is the work potential, and electrons are the charge carriers.  In semiconductor, this is the band gap, and electrons -- or the absence thereof (holes) -- are the charge carriers.  Whereas thermionic or field emission is required in vacuum (and so far, no one's yet devised a reliable field emission cathode, I believe is the problem?), thermal "emission" at room temperature suffices in semiconductors.
Indeed, there are semiconductor analogs of vacuum tubes: of the pentode, the FET (minus the screen current and secondary emission "kink"); of the triode, the SIT (static induction transistor).  And the operating principle of the thyratron for example, isn't far from that of the thyristor -- in both cases a plasma forms, in the sense of abundant freed charge carriers crossing a potential barrier, the production of which is ~proportional to current flow (hence the low and ~stable voltage drop, and latching operation).  (Although I'm not sure that a thyratron analog of a GTO exists; perhaps a grid electrode could block charges very close to the cathode or anode (in the "dark" barrier around either), while being insulated in some way so it doesn't draw current itself, but that seems like several big "if"s.)
So, if it's any consolation... they still glow, just at far IR?  :-DD
Seven Transistor Labs, LLC
Offline oz2cpu
    • webx.dk private hobby and diy stuff
« Reply #13 on: January 19, 2023, 01:22:12 pm »
WOW thanks a lot for those fantastic nuvistor teardown closeups
your photo skils clearly shows :-)
I have not seen any pictures before about nuvistors that good.
i released a short video about some of my nuvistors
https://youtu.be/5NJbeDd6sJ4
Radioamateur OZ2CPU, Senior EE at Prevas
EMC RF SMPS SI PCB LAYOUT and all that stuff.
youtube : oz2cpu teardown
Offline bidrohini
  • Country: bd
« Reply #14 on: January 19, 2023, 02:24:28 pm »
I am cool with BJTs :)
Offline rdl
« Reply #15 on: January 19, 2023, 03:23:47 pm »
Nice pictures. I remember some company made audio equipment using those. Maybe Musical Fidelity? I actually have a Nutube, but never did build the headphone amp it was meant for.
The following users thanked this post: SeanB, globoy
