Author Topic: Showing my VFD PSU  (Read 8066 times)
Offline RoloTopic starter
Showing my VFD PSU
« on: June 15, 2018, 05:26:02 pm »
I Like to show my current project, it's a PSU for VFD display's.
The PSU is for multiple digits VFD display's. It pretents to be a universal as in it's adjustable for different types of display's.
It contains a filament driver section with the LM4871. This is an audio driver by name but it's the same as the
(now out of production) LM9022 Filament driver. This driver is in self oscillating mode at arround 27 KHz.
Second part is a high freq. switcher (LM2733Y) for the high voltage. It goes up to 40V on a 5V input.
The filament driver is AC coupled and has a virtual center tap that is raised from the ground by a zener diode.
Inspiration for this design comes from the Noritake VFD fundamentals guide : https://www.noritake-itron.jp/eng/cs/appnote/apf100_vfd/index.html
The PSU runs on 5V DC, the filament and the HV can be enabled/disabled by a microcontroller.
Low on HV-PD shuts down the HV switcher, HV output goes to Vin (5V) when disabled. High on FIL-SD shuts down the filament.
This high can range from 3.3v to 5V so it's compatible with 3.3V controllers.
Shutting down the filament saves the lifetime of the VDF display when the controller has a power-save function.
If you leave the shut-down inputs not connected the filament and HV are both on. Easy for experimenting.
The filament power can be adjusted for different VFD display's by changing R7 and R10, this are 1206 type resistors.
R8 and R11 have to be about 5 times the hot resistance of the filament. (Got this bit of information from member Ian.M)
The HV output can be adjusted bij changing R2 and R13, I choose two in resistors in series here to get more values using the standard E values. See the LM2733 datasheet for specs and calculations on Vout and the value of C1.
I have made a PCB design in Diptrace and assembled one today, it's going to be used with a 8 digit dot matrix VFD.
Made some quick pictures of the 8 char display I'm working with now, also have a 13 char laying arround. That will be the next one that gets this PSU. Also want to make a graph about the filament output with different loads. To be continued.
« Last Edit: June 15, 2018, 05:47:06 pm by Rolo »
The following users thanked this post: Sparky49, Ian.M, NivagSwerdna, Telek
Offline apblog
Re: Showing my VFD PSU
« Reply #1 on: June 17, 2018, 02:54:30 am »
Thanks for posting this.  I am definitely going to add this to the list of things to review when I start my own VFD project soon.
« Reply #2 on: July 04, 2018, 07:27:13 pm »
The 13 character display is working now, it has it's own serial board and VFD PSU. In real life the contrast is much better, my phone can't handle the brighness very well.
Offline luiz10000
  • Country: br
« Reply #3 on: May 01, 2019, 05:56:42 pm »
hello, thank you for this circuit. I assembled one and it is working (I did not connect yet to my 16dig vfd) .... but are really c7/c8 1 microfarad capacitor? The ones in your photo are so small to be 1uF!!
« Reply #4 on: May 01, 2019, 06:07:40 pm »
Yes, they are 0805 sized 1uF caps. Where did you get the LM4871? I'm asking because there a fake's arround that do work but have lower output power then the original chips. This can be an issue on VFD's with longer filaments (like your 16 digit model). I  have both chips so can post what's printed on them if you need that info.
« Last Edit: May 01, 2019, 06:24:40 pm by Rolo »
Offline archeocomp
  • Country: sk
« Reply #5 on: October 05, 2019, 07:59:45 pm »
Hi Rolo, do you still have datasheet for that VFD display? I can't find it anywhere.
« Last Edit: October 06, 2019, 06:34:00 am by archeocomp »
« Reply #6 on: October 06, 2019, 06:41:26 am »
I do not have a real datasheet, the seller listed some printscreens of a datasheet, I extracted a PDF from that. It does not give the pinout but that's easy to find out. I will PM you some info.
Offline Telek
« Reply #7 on: August 01, 2020, 08:57:42 pm »
Thanks very much Rolo for all this! I was wondering if any further progress or finalization has been made to the design for this? I'm just trying to get some beautiful 20x2 starburst VFDs that I have running and am searching for the best PSU design.
Offline SYJON
« Reply #8 on: March 16, 2021, 09:22:36 am »
Awesome! Thanks for sharing! Long russian VFD can't live without this  ;D
Offline milom
« Reply #9 on: June 06, 2021, 05:09:56 pm »
Hi rolo, can I can't see schematic on post, can you place it? thanks for support...
Offline Ian.M
« Reply #10 on: June 06, 2021, 05:42:34 pm »
The following users thanked this post: milom
Offline milom
« Reply #11 on: June 07, 2021, 09:06:46 am »
Very thanks IAN!  8)
Offline notfaded1
« Reply #12 on: June 25, 2021, 03:07:46 pm »
I'm interested in something like this could power these I've acquired?
Bill
I really like 14 segment displays for doing alpha numeric data displays.  I've done this with nixie tube B-5791, B-8971, and big daddy B-7971's with smartsockets.  Seems a VFD like this could do some fun stuff with so many digits available.
« Last Edit: June 25, 2021, 03:11:10 pm by notfaded1 »
.ılılı..ılılı.
notfaded1
