Author Topic: Need help with a 37XR multimeter  (Read 5547 times)
Offline JolleTopic starter
« on: March 17, 2011, 01:12:51 pm »
Hi
I just got a broken Meterman 37XR for free, so at the moment I am trying to find the error and fix it.
So far I have discovered a resistor that doesn't look, or measures, very well (in fact it doesn't measure anything). You can see some pictures of the resistor below:
As you can see on the pictures the value is completely gone. So my question is if anybody can help me to find this value? maybe some of you out there have a similar multimeter and doesn't bother to tear it apart to check the value? or somebody might know something else that could be useful. In each case I would be very happy to receive help that could lead to a proper working multimeter :D
Regards
« Last Edit: March 17, 2011, 02:21:40 pm by Jolle »
Offline Bored@Work
Re: Need help with a 37XR multimeter
« Reply #1 on: March 17, 2011, 08:34:09 pm »
Looks like the resistor goes directly to one of the IC pins. If that is the case, try to get a datasheet for the IC and try to figure out what the pin is supposed to do. Maybe an application example in the datasheet helps, too.
Offline Fraser
« Reply #2 on: March 17, 2011, 10:03:14 pm »
The resistor has suffered a severe overload event. It would be prudent to determine what part it plays in the circuit. You can usually trace the tracks. Try to detrmine what could have led to the burn-up as replacing the resistor could just cause a repeat event with potential overload damage to another component. I have often found such damage caused by a shorted electrolytic capacitor, the resistor acts like a fuse in such cases and fries. Your resistor appears to have died a relatively non violent slow death as apposed to a dramatic and explosive overload. Hunt for the cause first.
I had a capacitor go short in my AVO Megger BM222 and the case was melted and charred by the heat produced by an associated SMD resistor. All this happened whilst it was sat in the off condition on a shelf ! The damn thing almost caught fire  >:(
As has been stated by Boredatwork, the ADC datasheet may help you with the purpose and value of the resistor. It may not be that critical depending upon it's purpose.
Or I would use a very high magnification microscope (analogue or USB digital type) to see if any remnants of the value remain on the burnt resistor. You can sometimes be lucky.
As a last ditch effort, I would fit a multi-turn high value trimpot (say 10K) across the resistors pads, then adjust it's value slowly from high to low and see what effect the resistor has on the opertion of the multimeter. From that you may be able to ascertain whether it is just a pull-up or a more important value that must be correct for calibration to be maintained. As the resistor cooked quite well on what was probably a low voltage event I would expect it's value to be below 1K but that is just a guess on my part.
« Last Edit: March 18, 2011, 08:43:24 am by Aurora »
Offline armandas
  • Country: jp
    • My projects
« Reply #3 on: March 17, 2011, 10:44:31 pm »
It's a 10k resistor, same as the one near it.
Offline Fraser
« Reply #4 on: March 18, 2011, 08:33:10 am »
And the ES51966 Analogue to Digital converter datasheet is here :
http://www.cyrustek.com.tw/spec/ES51966.pdf
It contains a nice example meter schematic including all values etc.
You should be able to work out the purpose of the fried resistor and what it connects to.
« Last Edit: March 18, 2011, 08:38:26 am by Aurora »
