Another issue is the 00 uf capacitor on the relay coil. This will delay the relay drop-out time resulting is a delay before the inverter power is applied. Also the capacitor will cause a slow release which could cause some additional arcing as the contacts switch. Minimize the capacitor sizing by using a full wave rectifier and only enough C to eliminate buzzing.
paul
