Author Topic: Changing a VU circuit  (Read 1463 times)
Offline carbon dude oxideTopic starter
« on: September 29, 2013, 07:33:16 pm »
Hello i have a small VU meter project going at the moment, and i have modified this circuit so far so that it is able to vary the brightness of the LED strip acording to the loudness :)
However i have run into a problem currently all 3 transistors on there are: BC547B 's and the amount of LED's i want to drive from this is a little bit too high unfortunatly :(
I would like to replace T3 to a mosfet to be able to handel about 8-10A (12m of RGB LED strip)
How would i go about modifying this circuit so that it uses a mosfet? Or can i put several of the BC547B in parralel with ballast resistors?
Everything Should Be Made as Simple as Possible, But Not Simpler
Offline madires
  • A qualified hobbyist ;)
Re: Changing a VU circuit
« Reply #1 on: September 29, 2013, 09:13:17 pm »
If you would PWM the LEDs then it would make sense to use a MOSFET. I'd go for a darlington configuration with a BD135 and some 2N3055.
« Last Edit: September 29, 2013, 09:22:09 pm by madires »
Offline dannyf
« Reply #2 on: September 29, 2013, 09:35:03 pm »
A (non-practical) solution would be to use T3's output to drive a (linear) mosfet driver / mosfet.
The only practical solution is to to use T3's output to modulate a pwm driver that drives the mosfet. One example would be to use a simplified version of your existing circuit to drive a 555 and then a mosfet, either directly or through a driver, depending on the mosfet used.
