Seeing as I can't compete in the
unlimited class, how about an entry for the vacuum tube class?
![Grin ;D](https://www.eevblog.com/forum/Smileys/default/grin.gif)
B+ supply 106.7V, from a DC-DC module; heater 6.0V (the power resistors are just to take up the slack, the bench supply is running about 10V). Tube is 5702, a subminiature version of 6AK5, an RF pentode. Ideal for breadboarding!
![](https://www.eevblog.com/forum/projects/challenge-thread-the-fastest-breadboard-oscillator-on-the-mudball/?action=dlattach;attach=1003137;image)
Running a good 233MHz, with harmonics apparent:
![](https://www.eevblog.com/forum/projects/challenge-thread-the-fastest-breadboard-oscillator-on-the-mudball/?action=dlattach;attach=1003135;image)
(This is a plot from my 8590A spectrum analyzer, and I don't know why the text is so badly placed. Axis is 100 to 800MHz, detector is peak, amplitude is 10dB/div, 0dBm ref (top axis).)
There's also a 20dB attenuator in line, between the pickup link and transmission line. So that's about 9dBm real power.
The tube is wired thus (pins from right to left):
A: B+
G2: B+
H2: GND
H1: 6V
G3: GND
K: 4.7uH + 220R to GND
G1: 3.5 inch jumper ('U' shaped) to GND
A 22nF film cap bypasses B+ to GND. A short jumper ties G2 to A. A slightly taller jumper ties G3 to H2.
Another single turn jumper, in a BNC-binding post adapter, couples to the G1 link and goes off to the spectrum analyzer.
The circuit is completed by the ~4pF between adjacent positions, making this a common-anode Colpitts oscillator.
![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
With over 9dBm of output power (and probably a lot more with a little tuning and stronger coupling), it seems to qualify for the purposes of this thread.
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
The self-resonant frequency of this tube is ca. 400MHz. It's not a hard cutoff; some amplification can still be possible up there. It's just very awkward to make use of, and might not even be usable as an oscillator. More compact types are preferred -- Nuvistors and planar types in particular.
This is a good point to mention some vacuum tube physics -- which is not necessarily poorly known (and not just because tubes aren't well known today), or unexpected; more that it's the kind of thing that, if it never crosses your mind, you'd never know, but if you see it and think about it, it'll become obvious what's going on.
At these frequencies, the mass of the electron cloud itself is substantial; the grid input impedance will be around 200 ohms || 9pF I think. (That may not seem like much compared to a BJT or MOSFET, but for a device that's normally comfortable with 10s of kohms around it, that's quite low!)
Mass by itself is conservative, so manifests as increased grid capacitance -- when cold, the capacitance of the grid to surrounding electrodes is only about 5pF, but when the cathode is hot, an additional ~3pF appears, and a little more when hot and biased on. These are due to the space charge and electron beam!
The resistance? Literally, work done on the electron beam. This power modulates the beam's intensity and velocity. And since the beam also carries space charge, the modulation is sensible on subsequent electrodes -- screen, suppressor and plate!
When the modulation reaches the plate, the beam intensity of course is received as plate (DC and signal) current. The velocity modulation smears it out, effectively reducing AC (signal) plate current at very high frequencies. Very fast tubes use incredibly close cathode-grid-plate spacing for this reason.
This works even when the electrode is not drawing beam current. That is, there is a nonzero transadmittance y_g1g2, y_g1g3 and so forth. This is a
nonreciprocal effect, too -- that is, y_g1g3 >> y_g3g1.
Reciprocity is a big deal, thermodynamically speaking. It generally means there's an energy input to the system. There may not necessarily be actual power gain, but the resulting isolation is still very unusual otherwise. In this case, of course, the heater is hot, and plate current is flowing, so there is ample input to the system. (Indeed, the cathode itself is a heat engine: electron emission is spontaneous even at 0V bias, thus net electrical power is generated. The efficiency is of course laughably pitiful, yielding microwatts or less for ~watts of heater power.
In this circuit, g2 is bypassed to ground, and g3 has a useless cross section (it really is just a suppressor, or at best has a few uS of transconductance to the plate, and even less coming from g1), so there isn't any good illustration of these effects with this tube type. It does however make things interesting for types with significant grid transconductance: dual-control pentodes, gated sheet beam tubes and pentagrid converters!
