Author Topic: Challenge Thread: The fastest breadboard oscillator on the mudball  (Read 63957 times)
Offline joeqsmith
Re: Challenge Thread: The fastest breadboard oscillator on the mudball
« Reply #75 on: June 09, 2020, 12:04:57 am »
Mounting the connector to the breadboard has been a problem.  The cables will put a fair bit of stress on it.   One solution would be to bolt a bracket to the breadboard with a panel mount connector.   I made up some Teflon cables today to connect to the breadboard and DSO.  These cables are very flexible, like a wet noodle.    I also have added a couple of copper wire loops around the coax to help secure it.
Offline TheUnnamedNewbie
  • mmwave RFIC/antenna designer
« Reply #76 on: June 09, 2020, 06:27:00 am »
But if "conventional" EM waves are the subject, the line between microwaves and IR is 300GHz. How close have hobbyists been able to get to that line?
I don't fully agree that the line between microwaves (well, technically millimeter-waves at that point) and IR is 300 GHz, generally people would say that you have sub-THz first (300 GHz -> a few THz).
There are at least a few HAMs (WA1ZMS, W4WWQ, W2SZ, WA4RTS) that have done some stuff at those frequencies, 300-400 GHz. This was all with 'conventional' RF techniques (IE, no lasers or optics, but transistors and diodes and mixers).
While the numbers are impressive, it isn't that fundamentally different from RF at a few GHz. The main issue is just that *everything* matters, and you need to use waveguides or expensive very small PCB technologies.
« Last Edit: June 09, 2020, 06:32:45 am by TheUnnamedNewbie »
The best part about magic is when it stops being magic and becomes science instead
"There was no road, but the people walked on it, and the road came to be, and the people followed it, for the road took the path of least resistance"
Offline joeqsmith
« Reply #77 on: June 10, 2020, 03:46:57 am »
Demonstrating LeCroy's Digital Bandwidth Interleaving along with my simple down converter, limitations with nail polish and my more recent attempt at making a fast oscillator on a breadboard.
Offline herc
« Reply #78 on: June 10, 2020, 10:31:40 am »
do you know the "twist oscillator" ? it operates in the GHz domain and  it is very intriguing, because it just needs 5 components. details can be found at this link:
http://jf.fourcadier.pagesperso-orange.fr/hyperfrequences/twist/oscill.htm
1001787-0
Offline joeqsmith
« Reply #79 on: June 10, 2020, 03:16:09 pm »
(Attachment Link)
I have not heard of the "twist" oscillator but the idea of using feedback has been around since the oscillator and using wire to form capacitors, inductors and delay lines is certainly nothing novel.   While it's more commonly known as a phase shift oscillator,  I guess I could call mine the double summersault oscillator with twist technology feedback.    Add a few spark plugs and claim it has something to do with free energy.  :-DD
Online SiliconWizard
« Reply #80 on: June 10, 2020, 04:34:51 pm »
(Attachment Link)
It's interesting! Getting ahold of the MSA08-86, which is apparently an Agilent part, may not be that easy though.
This shop seems to have it: https://dutchrfshop.nl/en/drfs-parts/73-msa08-86.html
(The whole article, in french: http://jf.fourcadier.pagesperso-orange.fr/hyperfrequences/twist/twist.htm )
Offline SilverSolder
« Reply #81 on: June 10, 2020, 06:25:14 pm »
(Attachment Link)
I'm guessing we are dealing with a literal translation from French, somewhere along the line -  what's the betting that the French word for "twist" is used similar to the English word "phase", right?
Offline joeqsmith
« Reply #82 on: June 10, 2020, 06:48:20 pm »
(Attachment Link)
I assumed it was from their picture of the twisted wires.   I looked it up using a French dictionary and it appears to have the same use.   We would need a French EE to chime in.
« Reply #83 on: June 10, 2020, 06:53:28 pm »
Indeed, it's related to the resonant circuit which is basically a twisted pair. "Le circuit résonant  est constitué d'une simple torsade, le "twist", dont la longueur conditionne la fréquence de fonctionnement de l'oscillateur. "
http://jf.fourcadier.pagesperso-orange.fr/hyperfrequences/twist/torsade.htm
« Reply #84 on: June 10, 2020, 08:07:23 pm »
So the "twist" is the whole LC circuit - both inductor and capacitor - in this design?   Or does it act as a "gimmick capacitor"?
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #85 on: June 10, 2020, 08:53:11 pm »
It's an open transmission line stub.  The first mode is a series resonance; it's a Pierce oscillator I believe.
Seven Transistor Labs, LLC
Offline joeqsmith
« Reply #86 on: June 11, 2020, 01:04:42 am »
Playing around with the new transistors..
The following users thanked this post: tautech, Simon_RL
Offline trash
« Reply #87 on: June 11, 2020, 11:21:21 am »
I'm guessing you're just referring to the BFR93 section and not the MSA08 MMIC. Does MMIC count as an "IC"?
(Monolithic Microwave Integrated Circuit)  Because with a careful piece of what man magic, I can make those critters oscillate very easily.
In some cases they have issues with them oscillating a bit too often.
Looks like I'm going to have to get in on this gig because I've got some ideas that really need to be put to the bench and now I have an excuse.
Offline LaserSteve
« Reply #88 on: June 11, 2020, 12:35:11 pm »
So if I stick a 10 mW X-band Gunn diode on a soldered breadboard does that count? I do not have any solderless ones.  I know for a fact I will see a Vhf fundamental. Then big spikes in X-BAND.
IN other words does it have to be clean? Because with a spark gap you could make oscillations out to say 60 Ghz.
Steve
"What the devil kind of Engineer are thou, that canst not slay a hedgehog with your naked arse?"
« Reply #89 on: June 11, 2020, 12:58:56 pm »
Steve
I was thinking the same thing (spark gap) but the challenge of filtering out and amplifying a signal up to 5V is still there...  and not exactly easy for high frequencies!
Offline joeqsmith
« Reply #90 on: June 11, 2020, 02:35:04 pm »
22AWG solid TFE insulation swept from 2.2-2.6GHz.
« Reply #91 on: June 11, 2020, 02:45:16 pm »
Absolutely. And it's mentioned in the article: "L'oscillateur est de type Pierce"
The following users thanked this post: T3sl4co1l
« Reply #92 on: June 11, 2020, 03:46:06 pm »
I'm not good at interpreting Smith charts...  What does it mean, that the plot follows the circle?
Offline joeqsmith
« Reply #93 on: June 11, 2020, 09:57:47 pm »
That's fine.  There are several good videos and text materials available for free on-line if you are interested.   For now, let me just show you a simple test.   In the attached graph looking at S11, I have swept the twisted wires shown above from 2350 to 2450 MHz.   I then swept a small trimmer capacitor over that same range.
« Reply #94 on: June 12, 2020, 04:02:47 am »
so is the twisted pair adding more capacitance, effectively, than a capacitor of the same nominal value - due to the time it takes for the wave to propagate to the end of it?
Offline herc
« Reply #95 on: June 12, 2020, 05:12:24 am »
no, it's called "twist oscillator", because it twists my shortwave-noob brain, trying to understand why a pair of twisted wires can act as a resonator ;-)
https://en.wikipedia.org/wiki/Stub_(electronics)#Resonant_stub
Stubs are often used as resonant circuits in oscillators and distributed element filters. An open circuit stub of length l will have a capacitive impedance at low frequency when β * l < π / 2 . Above this frequency the impedance is inductive. At precisely β * l = π / 2  the stub presents a short circuit. This is qualitatively the same behaviour as a series resonant circuit.
« Last Edit: June 12, 2020, 06:25:45 am by herc »
Offline trash
« Reply #96 on: June 12, 2020, 12:39:45 pm »
My first attempt came up with ~1.6GHz, I was able to push it to 1.8GHz and keep the stability.
Offline joeqsmith
« Reply #97 on: June 12, 2020, 03:21:04 pm »
 :-+  Nice job.
Offline trash
« Reply #98 on: June 13, 2020, 08:37:10 am »
Hitting a bit of a wall at the moment. 2GHz seems to be where I can get a stable carrier, above that it gets a bit sloppy.
I haven't resorted to any white man magic just yet and I've been sticking with a fundamental frequency.
I'll get to multiplication trickery later :D
Offline trash
« Reply #99 on: June 13, 2020, 08:50:09 am »
A few people mentioned using a tunnel diode but I didn't see anybody actually try.
So I thought I'd give it a go since I have a few of them sitting in a drawer.
Compared to the transistor based oscillator I'm able to get similar frequencies but there is a lot of spurious noise that comes with them.
You can see on the rectum paralyser there are carriers around 500-700MHz, with a lot of spurious noise at ~1.8GHz and a carrier at 1.895GHz.
The circuit is a simple voltage divider to give 700mV and I've used the wire lead of the diode as an inductor and a home made capacitor using some double sided circuit board sandwiched into the inductor loop. I tried to completely remove the capacitor and just rely on parasitic inductance but the result was more a white noise source around 3GHz rather than what I consider to be an actual carrier. I'll come back to this idea in the future when I've had a bit more time to think about it.
And a still have a few other dirty tricks up my sleeve to get up into C band. :D
