... TL431 and an LM317 ..
.. on for 72 hours and the thing drifted quite a lot ..
... military grade resistor (0.5%) and a simple 1% resistor ..
.. Oxidization and contact resistance might have to do with the drift but I can't tell...
I would have to solder this and test the circuit for something like 1000 hours to really get into conclusions.
I liked this experiment. The performance is quite good, but the experiment left me wondering:
What kind of components and voltage references get long-term stability as they are left powered on (i.e. burn in)?
your experiment for sure is quite instructing, to get a "feeling" for drift phenomena.
But, simply read the specifications for the different components, how they drift individually.
If you also analyse, which influence the exterior components have on the stability on the reference, you can estimate the total drift parameters.
I wonder, what kind of "military resistors" you've got.. there's obviously no classification / standard for such a term.
Mainly, the reliability or the stability is specified, but not the tolerance.
There exist 'Military' or "Automotive'
requirements for components, presently I don't remember the military standard, but for automotive, there's the AEC Q 100, 200, etc.
First of all, the reference itself has to be capable of delivering stability, over temperature and over time.
A simple stabilizer contains a simple Bandgap, perhaps, but is neither designed for good temp.-, nor time stability.
You'll need either a well designed bandgap reference, as in the REFxxx types, or an ovenized, buried Zener reference, as LM199, LTZ1000.
The external components, mainly the resistors, have to have low T.C. (around <= 5 ppm/K)
and low long term drift.
Therefore, thin film resistors are not sufficient (although perhaps being military grade reliable), but wire wound and metal foil precision resistors are required.
A burn-in of the assembled PCB may be helpful for reduction of stress in the solder junctions.
But this won't help for those simple stabilizers you've mentioned. They are simply too unstable from the principle of their design, that a burn-in would help.
To my experience, a burn-in or a monitoring is necessary only for the highest level of
guaranteed stability, as Fluke or HP/agilent delivers, but if you cleverly choose your components, the additional effect of pre-aging is neglectable for our non-profit purposes.
For the case of the LTZ1000, it's totally sufficient to design the standard circuitry from the LT datasheet, without further tricks, and you'll get an ultra stable reference, rarely anything will beat.
Well, and it's also necessary, that you have measurement equipment which is more, or at least equally stable, to rate the stability of your D.U.T.
That means, in this case, you need a high grade DMM, or alternatively you build 2, better 3 identical D.U.T.s to compare them against each other. If they show a big drift, they will drift apart. If they are stable, they will stay in line.
Regards Frank
