Author Topic: Line out to mic level adapter  (Read 1286 times)
Offline toto83Topic starter
« on: March 03, 2018, 12:48:25 pm »
Hello there,
I made a preamp circuit which is functionnal using one of the two amps of a TL082 amp.
It outputs a line level of +4dBu, about 1.730Vpeak.
I would like to connect it to a PC mic IN, which means (if I am not wrong) that I need a -50dB attenuator.
Can I build such attenuator from the op-amp?
Thank you for your help
Tom
Offline Paul Price
Re: Line out to mic level adapter
« Reply #1 on: March 03, 2018, 04:28:51 pm »
Just use two resistors to make a voltage divider, that's all you need.
« Reply #2 on: March 03, 2018, 10:58:22 pm »
Is there any formula to go from attenuation to resistor?
Offline DimitriP
« Reply #3 on: March 04, 2018, 12:18:47 am »
Resistor values for attenuator calculator
http://www.nu9n.com/tpad-calculator.html
Offline tooki
« Reply #4 on: March 05, 2018, 12:25:36 am »
Hello there,
Tom
First, check if the PC’s sound settings let you switch the input to line-level; most do, right in software.
