Author Topic: decoupling a high power signal?  (Read 2292 times)
Offline SArepairmanTopic starter
  • wannabee bit hunter
« on: October 08, 2013, 12:09:41 am »
I would like to decouple a high power signal (200mA rms) to remove offset errors from the amplifier.
Is it possible to use some kind of capacitor (tantalum slug?). Or is a transformer required?
The signal is 40kHz.
Offline baldengineer
  • James
    • Personal Blog
Re: decoupling a high power signal?
« Reply #1 on: October 08, 2013, 01:12:01 am »
Why do you consider 200mA to be "high power?  That sounds pretty low to me.
Capacitor Expert by Day, Enginerd at Night  ||  Personal blog:  www.baldengineer.com  ||  Electronics Videos for Beginners:  www.addohms.com
« Reply #2 on: October 08, 2013, 04:37:04 am »
Because I don't have ANY experience with signals that are not just fed into another op-amp.
Will a regular decoupling capacitor work?
Offline kalobg
« Reply #3 on: October 08, 2013, 05:32:51 am »
Capacitor should be ok for amplifier offset errors.  200mA is lower power range, but the cap will accomplish what you want regardless if 200mA is high or low power--just make sure you pick a cap appropriate for your application.
