Fellow masters,
I like to design a board that works with a 1.5AAA battery. The processor and some of the other ICs require 3V so, I will have to use a DC-DC converter, that is no problem. The problem is, my device will be off 99% of the time and leakage is not fun.
So, I am looking for a solution that would get the power consumption of the system during off mode less than 1uA @ 1.5V.
I have an on-off button but that is not mechanical, so I cannot cut off the power mechanically, I need to do it electronically.
For example, I looked for a DC-DC converter with a button press/bounce logic to turn on the system (where I could turn off via uP). I also looked for a 1.5 ultra low power uP that I can use to control some switches so that I can cut off the power to even DC/DC. (no such uP exists, at least based on my research) Neither these approaches proved useful.
Now, I am at a loss and open to suggestions.
thx, sgpee
