It really comes down to the receiver design. Since GFSK occupies less BW for a given symbol rate, the receiver can be made more sensitive by using a narrower filter (thus, less total integrated noise). The receiver will also have to be optimized for the gaussian filtered data, which may have a little intersymbol interference. But, by doing these things - GFSK should have a slight edge.
