I'm not sure where else to put this, but it is a sort of project so here goes..
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
I have an electrosense.org setup I'm installing at home and as part of the antenna installation I need to attach a few guy wires to the mast for the antenna.
Problem is, the 38mm (1.5") diameter stainless steel pole I am using doesn't fit any of the guy wire attachment brackets available here in Japan, because who needs a stainless mast anyway?
![Banging Head |O](https://www.eevblog.com/forum/Smileys/default/bangheadonwall.gif)
So, does anyone here have the capability to machine a 2-3mm thick disk of stainless steel, say 80mm in diameter, with a 38mm (plus a bit for clearance) hole in the middle and a few holes around the 'donut' for guy wire attachment?
I'll draw up a dxf a bit later to illustrate exactly what I need.
I can pay via paypal with a bonus of internet delivered gratitude.
![Cheesy :D](https://www.eevblog.com/forum/Smileys/default/cheesy.gif)
