Author Topic: Reproducing ST Design Gate Driver  (Read 1050 times)
Offline stainTopic starter
« on: August 25, 2021, 04:11:38 pm »
I try to reproduce the buck-boost converter from the "STM32F334 Discovery" board. Therefore I have drawn a KiCad Schematic and assigned the appropriate spice models. But unfortunately, I'm not able to reproduce the behavior. Or at least I think so, because the gate p-fet (P1) is in my opinion not properly driven.
[stm][/stm.png]
Picture form STM UM1735 Fig. 13
[kicad][/kicad.png]
KiCad schematic of the gate drive circuit.
A 1n capacitor is added as gate equivalent.
[waveform.png][/waveform.png]
The waveform at the "gate-caps"
I think something went wrong or I have a misunderstanding of the design.
For my own purposes, I would like to drive the Ubatt form 3.0-4.2V 3.7 nominal.
The logic level *_Drive may be at 3.3V but I would prefer 2.5V.
Because the p-fet from the reference design is not available, there could be some parameters to change for the p-fet (Vgs threshold).
« Last Edit: August 25, 2021, 04:15:44 pm by stain »
Offline bson
Re: Reproducing ST Design Gate Driver
« Reply #1 on: August 26, 2021, 08:37:46 pm »
What if you add the D6/D8 zener from the original circuit?  Without it there's no closed circuit on P1, so it's not surprising if it floats around the 1n cap.
« Reply #2 on: August 27, 2021, 09:04:58 am »
In my opinion the zener does nothing but protecting the gate against over voltage.
The capacitor is meant to represent the gate of the MOSFET.
I'm only interested in the gate-source voltage and the dynamic behavior.
I don't see a "floating" problem.
However, I did the simulation anyway with the "exact" diode model from the manufacturer:
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: August 27, 2021, 04:20:03 pm »
What else is connected to P1, is this the entire simulation?
Your riddle is, why isn't it pulling up to Ubatt every time.  Q2-D voltage should be of interest.
Seven Transistor Labs, LLC
« Reply #4 on: August 27, 2021, 04:58:52 pm »
I agree with that.
Here is the voltage at the gate and drain of Q2 together with P1.
This is the complete simulation, nothing more connected to the nets.
I have no clue, why the voltages are decreasing over time.
Offline T3sl4co1l
« Reply #5 on: August 27, 2021, 07:50:08 pm »
Netlist?
« Reply #6 on: August 28, 2021, 11:01:50 am »
There you go
Offline T3sl4co1l
« Reply #7 on: August 28, 2021, 12:59:56 pm »
Q4 doesn't show up, does it have a model?
Can you also post the BC817 and 2N7002K models?  (I'll assume SMAJ and SIGNAL_SCHOTTKY are big libraries, and working fine anyway.)
Q3 and Q4 are probably wired wrong, with Q4 showing as a short circuit B-E (both sides are apparently Net-_Q2-Pad1_).  It's still not obvious how that would give the waveform.
