Author Topic: K-12 student $20 scope circuit  (Read 2283 times)
Offline MephitusTopic starter
  • Dashing, no?
« on: January 07, 2016, 06:06:45 pm »
Original page: http://www.ece.utah.edu/~ecectools/_Outreach/_Outreach.htm
PDF: http://www.ece.utah.edu/~ecectools/_Outreach/StephenSiebOscilloscope/SSieb20DollarOscRev2.pdf
I was looking around the locally available free EE curriculum and found this rather nifty little circuit project for a PIC controlled and very very basic scope. Thought it would be worth posting for others to use or have as a starter educational project. There are other circuits and such available on the link above. Share and enjoy!
A true gentleman must be prepared for anything. - Pepe le' Pew
Offline eugenenine
Re: K-12 student $20 scope circuit
« Reply #1 on: January 08, 2016, 09:51:35 pm »
Amni reading that correct that they are connecting the pic's ground to 5v?
Offline SPRX
« Reply #2 on: January 08, 2016, 11:22:33 pm »
eugenenine, it is correct. PIC Gnd should be connected to +5v to achieve specified input of -4.5 to +4.0 V. In the schematic, input Gnd id is also connected to +5v
Offline Jay_Diddy_B
« Reply #3 on: January 08, 2016, 11:53:34 pm »
Don't trust somebody who wires the protection diodes like this:
Jay_Diddy_B
Offline LukeW
« Reply #4 on: January 09, 2016, 12:01:16 am »
It might be easier to get your head around it if you "rename" the +5V rail to ground, the ground to -5V and the +9V rail to +4V.
Still looks like a very dodgy design though.
Online Andy Watson
« Reply #5 on: January 09, 2016, 12:24:34 am »
Looks like whoever drafted the schematic was having a bit of an "off" day. The button/switch inputs apparently sense the "+5V" ground.
I'm sensing undergrad group-project write-up !
