Loading [MathJax]/extensions/Safe.js
Author Topic: Networks for peaking frequency response?  (Read 719 times)
Offline T3sl4co1lTopic starter
    • Seven Transistor Labs
« on: February 11, 2021, 03:54:03 am »
Anyone know if there's a general (n-pole) topology for peaking, with one port C-loaded, the other R-loaded?
The famous T-coil method applies for both ports C-loaded only, with the R load being incidental (typically bias).  I want a network which peaks the response into the R alone (a wideband RF power amp is an illustrative example).
The only method I'm currently aware of, is series peaking, which stinks (~50% bandwidth gain even with 4 poles in your basic ladder topology).
Bit of an aside, there is one method, a distributed amplifier.  But I mean for a single amp only.
I do have a bib reference this time!  Wideband Amplifiers, Starič and Margan.  Part 2 gives analysis of several useful peaking circuits.  I kind of doubt that these are exhaustive among useful peaking circuits, though?
Seven Transistor Labs, LLC
Offline srb1954
  • Retired Electronics Design Engineer
Re: Networks for peaking frequency response?
« Reply #1 on: February 11, 2021, 05:13:22 am »
Have you also looked at the Vertical Amplifier Circuits handbook in the Tektronix Circuit Concepts series?
« Reply #2 on: February 11, 2021, 05:55:33 am »
Those are entirely of the both-C-load type.
